New LED Recessed In Drop Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2014, 11:16 AM   #1
New LED recessed in drop ceiling
I haven't been able to find any information on this either here or via Google...
I'm installing the electrical in the area above what will be a suspended ceiling. Normally, the cans are wired to each other via BX cable strung in the plenum area. The BX is necessary (I assume) because Romex will not satisfy code.
I would like to install LED lights in this ceiling and would like to use "new" LED cans as opposed to LED retrofits that go in existing cans. I have a bunch of existing romex installed above the floor joists and I've removed the old basement lights and boxes and was hoping to run those wires directly down to the new LED lights.
Does the short run (from just above the floor joist to the connection box on the new LED light) have to be BX?
As I read this, I understand that it might not make a lot of sense, but I'll leave it like it is and clarify if need be.
Thanks in advance for any help.
-Jim
jimx is offline   Reply With Quote
Old 01-05-2014, 11:19 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I have never seen a plenum rated ceiling in a residential basement.
The Following User Says Thank You to k_buz For This Useful Post:
jbfan (01-05-2014)
Old 01-05-2014, 11:32 AM   #3
An old Tradesmen
Rewards Points: 7,400
Is your furnace's return duct just ran up to the ceiling and then opens in up in it pulling room return through it? If not, its not a plenum ceiling.
Old 01-05-2014, 11:56 AM   #4
Licensed electrician
Rewards Points: 1,630
Local amendments may change what the NEC allows. Check with your local building officials.
Old 01-06-2014, 10:40 AM   #5
By "Plenum" I simply meant the area above the drop ceiling and below the floor of the next level. I didn't mean to imply that there was negative pressure or any features of an actual plenum that were significant in answering the question.
Sorry for that.
-Jim
Old 01-07-2014, 05:26 AM   #6
An old Tradesmen
Okay, its not a plenum ceiling then. Thats a good thing.
Old 01-07-2014, 05:30 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Have you looked into low voltage LED pucks that just push into a hole? You will need a supply transformer somewhere...but the low voltage wiring might save you some code issues...and the low voltage LED's are easier to dim...if that is a feature you want.
Old 01-07-2014, 08:42 AM   #8
No, I hadn't thought of those... I'll check them out.
Junction box in ceiling accessible through hole for recessed light? jp1423 Electrical 14 11-08-2012 09:10 AM
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 12:21 AM
Basement - drop ceiling jgrohol Building & Construction 11 04-01-2011 12:39 PM
Recessed Lighting on a drop ceiling Michael Mooney Interior Decorating 1 02-16-2011 01:56 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
