Old 05-23-2012, 09:38 AM   #1
New LED downlights don't dim enough..Dimmer switch options?
I just installed new 3" diameter LED downlights in my living room renovation. Ceilings are at 7'-11, and I spaced them at 42" apart. Each lamp supposedly equals approx a 40 W incandescant PAR lamp, but the light is very bright white light. I wired them to a dimmer switch but I thought the switch would take them from almost off to fully on. Instead, the lowest dim setting is about 50% of brightness. Can anybody point me to a better switch option which might provide more range of dimming? The LED's are Lithonia LK3 and the switches are the LED dimming kind sold at Home Depot. Thanks in advance for all replies.
tpagel is offline   Reply With Quote
Old 05-23-2012, 09:56 AM   #2
JOATMON
ddawg16's Avatar
Did you use the right dimmer? The dimmer for an incandescent is different than for LED's.
If your getting some flickering.....then you do have the wrong dimmer.
FYI....HD and Lowes typically only carry the common stuff.....chances are the dimmers they have on the shelf are for incandescent.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 05-23-2012, 10:07 AM   #3
I did use the Lutron LED dimmer switch, and the fixtures say they are dimmable on the package.
http://www.lutron.com/Products/Stand.../Overview.aspx
After a little more reading, I see there is a dimming range adjustment on the switch itself. I will try that and hope that solves my issue.
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 02:28 PM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 04:26 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 01:25 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 11:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
