New L.E.D. Lights For Can Lights Good/Bad? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 06:50 PM   #1
New L.E.D. lights for can lights Good/Bad?
Has anyone used the new led bulds for can lights?
I like the eco use even though they are costly.
bjlffire is offline   Reply With Quote
Old 04-05-2010, 07:34 PM   #2
Rewards Points: 81
Color temperature? To my eyes, even 3000K is too blue-white for interior use.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 04-05-2010, 08:31 PM   #3
Remodeling Contractor
another thing to watch out for. The ones sold in box stores are not quality. Reports have shown that these 30,000 lamps only last 1000. So no savings are to be had. If you need these lights on a dimmer the Led are fine. Otherwise stick with the CFL's
Old 04-05-2010, 10:46 PM   #4
This is true nearly 100% of the time. Box store customers will not pay what a quality LED lamp costs, so the box stores don't buy the quality brands for the most part.
LED lamps in the PAR30 and MR16 styles have been pretty popular from what our company has seen - especially the MR16 in places like private boxes at stadiums/etc.
If you're serious I would also recommend looking into the LED retrofit modules from Halo. They make them for the 6" and 4" cans and they are available in multiple color temperatures so you won't be stuck with the blue light the cheap LED lamps put out.
Good luck.
brich is offline   Reply With Quote
Old 04-05-2010, 11:47 PM   #5
you can also buy CFL that are the same size and profile as the R30 lamps commonly used in recessed lights. These are also available for the dimming needs.
Old 04-06-2010, 02:50 PM   #6
I tried CFL floods in one of my rooms. I liked the light, but using the dimmer made these bulbs buzz, even though it stated on the box that they were dimmable. Do I need a certain type of dimmer switch for CFL floods?
Tx!
bobssurfin is offline   Reply With Quote
Old 04-06-2010, 02:55 PM   #7
some do some do not. All have issues. Two things... if you normally dim the lights you are already saving energy. If this is not the case then you need to use the LED's
Old 04-06-2010, 02:59 PM   #8
The buzzing only occurs when they're dimmed.
Old 04-07-2010, 03:09 AM   #9
Union Electrician
goose134's Avatar
There are dimmers out there that are designed to work with CFL's. Lutron has one that is reasonable.
http://www.lutron.com/CMS400/page.aspx?id=22117
goose134 is offline   Reply With Quote
The Following User Says Thank You to goose134 For This Useful Post:
bobssurfin (04-07-2010)
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Landscape lights BlueBSH Landscaping & Lawn Care 2 02-24-2010 10:43 PM
Outdoor lights (Soffit etc) DIY_JC Electrical 2 09-25-2009 12:45 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
