New HVAC Line To Airhandler In Basement. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 09:03 PM   #1
New HVAC line to airhandler in basement.
I'm currently working on a house built in the 1930's. The electrical is a mess with a combination of a switch panel and a fuse box with most of it still being knob and tube. I'm running a new electrical line to the air handler in the basement. This is due to it currently being tapped off a light circuit which also feeds an outlet in the kitchen, a bedroom, and half the outlets upstairs. (There's no rhyme or reason to the current electrical setup).
My main question is I'm running 12NM through bored holes in the studs to the air handler. Once I get to the handler and run it down to where it enters the appliance and switch box will I run in to codes problems. Should this run in the basement be inside a conduit or is NM cable okay?
Any guidance would be appreciated.
nsberkland is offline   Reply With Quote
Old 04-24-2012, 09:11 PM   #2
Licensed electrician
Rewards Points: 1,028
Many will run a conduit sleeve up to the ceiling and run the cable in it to the unit.
Don't forget any unit disconnect switches or receptacles for condensate pumps.
Old 04-24-2012, 10:28 PM   #3
I=E/R
a7ecorsair's Avatar
Don't forget that any receptacles have to be GFI
a7ecorsair is offline   Reply With Quote
Old 04-25-2012, 08:39 AM   #4
assuming the basement is unfinished, of course
itsnotrequired is offline   Reply With Quote
Old 04-25-2012, 11:54 AM   #5
Code05's Avatar
Rewards Points: 1,104
I doubt this space qualifies as habitable.
(5) Unfinished basements for purposes of this section,
unfinished basements are defined as portions or areas of
the basement not intended as habitable rooms and limited
to storage areas, work areas, and the like
Code05 is offline   Reply With Quote
Old 04-25-2012, 12:18 PM   #6
the local receptacle required by 210.63 could conceivably be in a finished area of the basement and thus not have to be a GFCI receptacle. i wasn't suggesting the air handler was in a bedroom.
Old 04-25-2012, 02:24 PM   #7
Code05's Avatar
I will concede to that .
Rerouting Central HVAC Line Perry401 HVAC 22 11-22-2011 05:05 PM
HVAC return in basement stringers HVAC 0 11-18-2011 03:14 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
HVAC for finishing basement ossrocks HVAC 3 12-09-2009 01:15 PM
