Old 01-16-2006, 10:20 PM   #1
New homeowner here...circuit breaker question
New homeowner - thanks in advance for any help.
As my wife was using a new space-heater, we heard a "pop" and the power outlet went out and circuit breaker tripped. Turned to off position then on position. However, the outlet still does not work. It's triggered by a light switch which sounded like it "popped" too and hot to the touch after the incident.
Do I need to replace the switch or the circuit breaker or call an electrician?
fenway71 is offline   Reply With Quote
Old 01-16-2006, 10:42 PM   #2
Oldguy
Rehabber's Avatar
You probably have a bad connection at the light switch. If the wiring at the switch was pushed into the spring terminals on the back of the switch, replace with a new switch, but do not use the push in terminals. Make a hook at the end of the wires and use the screw terminals.( don't forget to turn off the breaker before you work on the switch.)
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-16-2006, 11:12 PM   #3
jproffer's Avatar
I personally wouldn't feel very good about using a switched outlet for a space heater anyway. I don't know the legalities or code issues, if any, but seems to me that switches are meant to send power to 100W light bulbs not 1500W space heaters. Just MHO, but I'd find a different receptacle to use that was a constant hot.
jproffer is offline   Reply With Quote
Old 01-17-2006, 09:49 PM   #4
Thanks. A friend says I just need to replace the switch. As you mentioned, space heater and dimmer switch was a dumb combo.
Old 01-17-2006, 10:12 PM   #5
Electrical Contractor
A dimmer switch is even a worse situation. By code you can not use a dimmer to control a recepticle. The dimmer switch was most likely rated for 600 watts while the heater is useing 1200/ 1500 watts. I hope you remedy this situation before other problems occur.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-18-2006, 06:27 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
This is one small section of the code people love to violate. Dimming a receptacle.
Yours is a prime example of why this is bad.
Think about if it was your new plasma TV!
Old 01-18-2006, 08:04 PM   #7
World famous jerk.
Right! I had a customer burn up her vacuum sweeper using it in a receptacle controlled by a dimmer. The dimmer was set at halfway. I'm sure the sweeper sounded funny and didn't pick up very well right before it died.
mdshunk is offline   Reply With Quote
Old 01-18-2006, 09:39 PM   #8
Thanks everyone for the advice. The previous owners (we moved in less than a month ago) had the dimmer switch set-up which I thought was bizarre and unnecessary.
Anyway, I successfully reinstalled with a regular switch and everything is working fine. I feel like a true handyman now....ha!
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Heat Pump compressor trips circuit breaker joejean HVAC 3 08-28-2006 01:15 PM
Replacing a circuit breaker PaulGray Electrical 3 05-13-2006 10:17 PM
Circuit breaker keep retripping Gregg Electrical 4 02-18-2006 06:11 AM
