New Here - Question About Light Switch Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 02:14 PM   #1
New here - Question about light switch box
Hi I'm new. Just had a question about how to mount a light switch box. As far as I know, electrical boxes for lights, plugs and switches have to be properly mounted to a wall stud or ceiling joist or some sort of 'structure'. Is this true? Reason is we are going through a commercial reno, and I have some seen some stuff that I am pretty certain is a bit questionable. They are putting up walls and electrical here and here is how I saw one of the light switches mounted for one of the offices. It is just a section of a steel stud screwed to the drywall, and then the light switch attached to it. Am I right to think this is wrong? Should I be telling the owners about the contractors work?
[IMG][/IMG]
dooeet is offline   Reply With Quote
Old 05-23-2013, 02:17 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
That's fine!
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Philly Master (05-23-2013)
Old 05-23-2013, 02:19 PM   #3
ok, thanks...
Just wanted to make sure because I have always seen these boxes directly attached to wall studs.
Old 05-23-2013, 02:20 PM   #4
Licensed electrician
Rewards Points: 1,266
The cables need to be secured within 12" of the box. Other than that it is fine.
Ceiling fan - Light on dimmer switch, Fan on normal switch renderflux Electrical 3 09-10-2012 02:36 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 07:27 AM
Simple Question on Light Switch Series hagler Electrical 19 03-20-2012 08:46 AM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 06:24 PM
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 09:35 AM
