New GFCI Outlet Won't Work - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 01:42 AM   #16
Originally Posted by sublime2
Incorrect. A GFI will work properly without a ground. It will not protect equipment without a ground, hence the label that comes with it indicating such.
Rob's statement was in response to oh'mike's comments about getting an electrical tester. What Rob was pointing out is those testers won't trip the GFCI if there is no ground wire present. You need to use the integral tester on the GFCI receptacle if there is no ground wire present.
clydesdale is offline   Reply With Quote
The Following User Says Thank You to clydesdale For This Useful Post:
micromind (05-28-2013)
Old 05-28-2013, 09:44 AM   #17
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Think you may need to re read what he posted.
a GFI will trip on a fault if there's no ground present, but it will not trip by pushing the test button if there's no ground.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Old 05-28-2013, 10:00 AM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,796
Could there be different circuted GFI's. I replaced a bunch on my daughters ungrounded 1953 build, and while I can't go over there now, I could swear they trip with their integral trip test button.
They definately won't trip with the "plug-in" tester, as that uses a jump to ground to fault it.
My memory could be wrong though, but I could swear the intternal trip will trip it. It was my first experience with an old non-grounded branch system.
Peter
MTN REMODEL LLC is offline   Reply With Quote
Old 05-28-2013, 10:16 AM   #19
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Peter
You are correct!
Old 05-28-2013, 09:43 PM   #20
Licensed electrician
Rewards Points: 1,892
If you mean the test button on a 3 light tester you are correct. If you mean the built-in test button you are incorrect.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
clydesdale (05-28-2013), MTN REMODEL LLC (05-28-2013), SPS-1 (05-01-2016)
Old 05-28-2013, 09:51 PM   #21
DIY staff
Rewards Points: 7,174
I learn something new every day, here in electrical---Thanks---
Old 05-29-2013, 09:27 AM   #22
jproffer's Avatar
Rewards Points: 718
Originally Posted by joecaption View Post
Did you cut the breaker back on, needs power to reset.
Checked to make sure there's incoming power?
100% sure you have the incoming power on the load side of the outlet not the line side? Should be marking on the back side if the outlet to tell you which is which.
I figure you know what you meant, and just typed it wrong, but I *think* this is backwards....isn't it?
The incoming feed comes to the line side.
EDIT: Sorry Joe, I just read down far enough to see the other similar comment.
jproffer is online now   Reply With Quote
Old 05-01-2016, 04:47 PM   #23
Rewards Points: 2
Re: new GFCI outlet won't work
My new GFCI would not work, had the green light but no power in the outlets.
Turns out that the new ones have different wiring configuration, I switched the top black and bottom, same on the white side, works fine. My local electrician gave me this info via phone (Silva Electric-Tracy, CA)
Crash1952 is offline   Reply With Quote
Old 05-01-2016, 05:14 PM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
Originally Posted by micromind View Post
I didn't state 'work', I stated 'trip'. I should have been more concise; a GFI will trip on a fault if there's no ground present, but it will not trip by pushing the test button if there's no ground.
Sorry for the confusion.
Deleted
Coastal South Carolina
Tags
gfci outlet , outlet
Another GFCI Question Jzone99 Electrical 5 09-16-2012 01:56 PM
GFCI special application--on demand for brief period highdeserthome Electrical 33 01-20-2012 11:19 AM
how to know/test if an outlet is GFI protected (water test doesn't work)? DanDaMan Electrical 17 03-07-2011 05:38 PM
Replacing outlet to new GFCI - Wall switch Protonix Electrical 13 04-09-2009 08:36 AM
Problems with GFCI Outlet FieldersChoice Electrical 11 01-04-2009 01:53 PM
