New GFCI Outlet Won't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 11:13 AM   #1
new GFCI outlet won't work
I have a GFCI outlet in my bathroom that tripped when my wife was using a clothes steamer. It would not "un-trip" afterwards. So I bought and installed a new GFCI outlet, but it still won't work.
Every other outlet/switch in my house still works. The outlet in question does not feed out into any other outlets, it just receives. I installed the outlet the same way the old one was installed (which worked for years and years just fine). I have made sure the wires are tightly secured into the outlet, and I have tried pressing the test and reset buttons multiple times.
What could be my problem? Could it be the wires themselves, even though everything else works fine?
will107777 is offline   Reply With Quote
Old 05-27-2013, 11:18 AM   #2
Rewards Points: 2,516
In the near past, Have you removed, replaced or reconfigured any electrical devices prior to the GFCI tripping and not resetting?
Is the insulation nicked off any of the wires when you pushed it back in its box?
Pull the GFCI out of the box and try resetting it.
hammerlane is offline   Reply With Quote
Old 05-27-2013, 11:22 AM   #3
Rewards Points: 204
Cycle the power off, then on at the breaker and then try to reset it.
I have also run across GFCI receptacles that are very hard to reset after pushing the test button.
Is this in a metal box or plastic?
Old 05-27-2013, 11:22 AM   #4
Rewards Points: 14,026
Did you cut the breaker back on, needs power to reset.
Checked to make sure there's incoming power?
100% sure you have the incoming power on the load side of the outlet not the line side? Should be marking on the back side if the outlet to tell you which is which.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
hammerlane (06-01-2013), MTN REMODEL LLC (05-27-2013)
Old 05-27-2013, 11:24 AM   #5
Yes I am sure the wires are connected right...tried flipping the power on and off as well. Getting nothing at the outlet though - and again, everything else works perfect. I'm at a total loss here.
Old 05-27-2013, 11:28 AM   #6
DIY staff
Rewards Points: 7,174
Did you test the wires to see if you have power to the outlet?
Old 05-27-2013, 11:32 AM   #7
No I didn't test the wires. Could it be the wires even if every other outlet and switch still work fine though?
Old 05-27-2013, 11:46 AM   #8
DIY staff
Quite possible----in older homes (1970s) the bath/kitchen and outside outlets were all wired together to save costs----frequently, when a bath outlet is not working, the wires are dead and need to be traced to another GFCI outlet or to a gfci breaker.
Test it--sure beats trying to get an outlet to work that has no power.
Old 05-27-2013, 12:29 PM   #9
Joe I think you meant be 100% sure you have incoming power on the LINE terminals not the LOAD.
clydesdale is offline   Reply With Quote
Old 05-27-2013, 01:28 PM   #10
joed's Avatar
Rewards Points: 13,354
I agree with OH'MIKE. Could be another GFCI on the same circuit (often in the garage)that has tripped and you really don't need the GFCI in the bathroom as you have protection elsewhere.
Old 05-27-2013, 01:36 PM   #11
DIY staff
I'm always surprised by how few homeowners have a simple electrical tester .
If you need to buy a tester--get a two wire tester ,not a noncontact tester.
I like Wiggy style testers---a Multi-meter will work well also---but are a bit fragile for heavy field use----
In order to test a circuit you want to touch ground and then the power with the second probe---
If it is live--then repeat the test using the neutral and power---If it does not register,you will know that the neutral is out----
That can't be done with a non-contact tester----so don't get one of those----
Old 05-27-2013, 04:13 PM   #12
Idiot Emeritus
Rewards Points: 1,492
Is there a ground wire present? A typical GFI won't trip if there's no ground.
Also, is the black wire on the side with the darker colored screws? And is the black actually hot? A lot of modern GFIs won't reset if the polarity is reversed.
One quick test to see if there's another GFI ahead of this one is to check continuity between neutral and ground. If it's open, most likely there's another GFI in the circuit, as a tripped GFI opens both the hot and neutral.
Rob
micromind is offline   Reply With Quote
Old 05-27-2013, 09:46 PM   #13
Rewards Points: 826
Rob
Sorry Rob-o no ground wire needed for a gfci to work. They operate via differential transformer. Any imbalance between hot and neutral over 5mA will trip unit. Ground or no ground.
curiousB is offline   Reply With Quote
The Following 2 Users Say Thank You to curiousB For This Useful Post:
MTN REMODEL LLC (05-28-2013), SPS-1 (05-01-2016)
Old 05-27-2013, 10:24 PM   #14
Idiot Emeritus
I didn't state 'work', I stated 'trip'. I should have been more concise; a GFI will trip on a fault if there's no ground present, but it will not trip by pushing the test button if there's no ground.
Sorry for the confusion.
The Following 2 Users Say Thank You to micromind For This Useful Post:
jbfan (05-28-2013), MTN REMODEL LLC (05-28-2013)
Old 05-27-2013, 10:31 PM   #15
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Incorrect. A GFI will work properly without a ground. It will not protect equipment without a ground, hence the label that comes with it indicating such.
sublime2 is offline   Reply With Quote
Tags
gfci outlet , outlet
Another GFCI Question Jzone99 Electrical 5 09-16-2012 01:56 PM
GFCI special application--on demand for brief period highdeserthome Electrical 33 01-20-2012 11:19 AM
how to know/test if an outlet is GFI protected (water test doesn't work)? DanDaMan Electrical 17 03-07-2011 05:38 PM
Replacing outlet to new GFCI - Wall switch Protonix Electrical 13 04-09-2009 08:36 AM
Problems with GFCI Outlet FieldersChoice Electrical 11 01-04-2009 01:53 PM
