New GFCI Outlet From Existing Light Fixture? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 02:32 PM   #1
I am trying to add a new GFCI outlet (that I'd like to always be hot) from an exsting light fixture and need to know the connections to make. Here is what I have:
Switch - one red and one black wire connected to the switch
Light Fixture - a black, red, white and ground
New Outlet - ran new wire with black, white and ground from the light fixture down to the new outlet box
How do I make the connections to keep the outlet hot and the light on the switch?
Thanks!
krsnyder8 is offline   Reply With Quote
Old 08-06-2011, 04:59 PM   #2
Electrician
Rewards Points: 760
White to white and you will have to figure out if either the red or blk is a constant hot.
darren is offline   Reply With Quote
Old 08-06-2011, 05:06 PM   #3
So white from the fixture, original wire and new wire going to the outlet all nutted together?
Then once I figure if the red or black is always hot - the always hot to the black new wire for the outlet? and the other to the black of the fixture?
Old 08-06-2011, 05:20 PM   #4
Electrician
Rewards Points: 760
That is correct unless you want your light on all the time and a switch for the new plug
Old 08-07-2011, 07:23 AM   #5
Worked like a charm. Thanks so much for the help!
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 03:44 PM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 01:23 AM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 06:38 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
