New Gfci On New Circuit Pops - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 10:55 PM   #31
I believe a GFCI is not required on a sump pump. Any GFCI might occasionally trip with a pump, and if your away, you may discover a flooded basement upon return.
Tom D is offline   Reply With Quote
Old 11-14-2008, 09:55 AM   #32
Rewards Points: 270
Thanks Tom - there was at least one other reply in this thread that said the same thing - and some opposite points of view too. I haven't forgotten about this thread - just had some other crap happen over the last month or so that's been keeping me from getting to the project. I think it's still worth swapping out GFCI's even as a sanity check - as mentioned I had another GFCI (original - still tests ok) that never flipped on this pump, but the new one has - which is weird.
-randy
rtoni is offline   Reply With Quote
Old 11-14-2008, 10:46 AM   #33
bradnailer's Avatar
When I wired my wood shop, I was required to have a GFCI in each circuit and believe it or not, I got a bad one. It kept tripping. I checked all the wiring and it was just fine. I replaced the GFCI and the new one never tripped.
PS: They were all Leviton's from Lowe's.
bradnailer is offline   Reply With Quote
Old 11-14-2008, 11:26 AM   #34
Rewards Points: 270
thanks bradnailer - confirms previous posts about flaky units floating around. Doesn't make me feel too warm and fuzzy about a device that's supposed to save lives. Gotta wonder about quality control (but I won't regurgitate my made-in-China rant...)
Old 11-14-2008, 01:27 PM   #35
With all these discarded GFIs, you could cannibalize the toroidal xformer out of one of them and make your own differential-current tester with one of these and a voltmeter. You might also need a "burden resistance."
No more guessing at $15 a pop.
Old 11-14-2008, 02:02 PM   #36
Rewards Points: 270
or i could go back and stick my arm in the sump pit - either way I think i'd end up electrocuting myself
seriously, I had to go look up "toroidal transformer"
it'd be like running with scissors in my case....
Old 11-14-2008, 02:03 PM   #37
So that is what is sticking out of my belly!!!
Old 11-14-2008, 02:59 PM   #38
Rewards Points: 270
oops - sorry 'bout that...
honest - that usually doesn't happen when someone answers my questions here...
Old 11-15-2008, 09:12 AM   #39
Fluke makes some kind of leakage or differential current tester using a clamp-on probe, but this thing might take quite a while to pay for itself.
Old 11-15-2008, 10:18 AM   #40
Electrician
Only if your area has a state amendment.
Hogwash, GFCI's do not occasionally trip. If someone is really worried about their basement, then I suggest they install a battery backup pump as well.
chris75 is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Testing circuit with GFCI protection Hodag Electrical 4 09-15-2008 10:43 PM
Microwave trips GFCI on a different circuit! Frank Kolwicz General DIY Discussions 7 06-01-2008 08:48 PM
GFCI circuit Cossack Electrical 31 03-21-2008 12:34 AM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 02:41 PM
