New GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 04:28 PM   #1
New GFCI
I was trying to replace a GFCI in my bathroom after I heard buzzing. I removed the GFCI and found a lose connection with a lil melted plastic wire.
The new GFCI is a simple strip a straight wire push in the hole type. However it doesn't work because the old wire had a separate slot for a 240v wire.
What kind of GFCI do I need?
I have 2 black wires
1 white
1 white 120v
1 white 240 v
How is this setup suppose to work?
Lindgren21 is offline   Reply With Quote
Old 02-07-2011, 08:54 PM   #2
Registered User
Termite's Avatar
Sounds really, really squirelly to me. I'm baffled. You should not have 240v anywhere near your bathroom GFCI receptacle.
Can you post a picture or two of the old one, as well as the wires you've got?
Old 02-08-2011, 11:50 AM   #3
Rewards Points: 252
Are you are in the US? How do you know you have a (white) wire with 240 volts on it? That would be almost impossible in an average American home. How did you get these voltage readings. Do you have a meter to check with? I think you should call someone who knows about this, before you hurt yourself or someone else.
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
GFCI Stumper ksqrdks Electrical 2 04-03-2010 06:24 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
