New Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2008, 04:08 PM   #1
New garage
Im building a new garage and need some electrical advice. First I'm wanting to eventually put a welder in it and want to know if 100 amp is good enough. Second the garage is about 40 feet from my meter and I want to bury the line, how deep should I bury it, what size wire to use, and what should I cover the wire with.
Any advise would be helpful
deere2440 is offline   Reply With Quote
Old 03-01-2008, 04:20 PM   #2
Rewards Points: 6,652
http://www.nfpa.org/freecodes/free_a....asp?id=7008SB
Old 03-01-2008, 06:01 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
100 amp would be adequate unless you are using an industrial sized welder and have a lot of additional loads.
wire size #3 copper (USE or THHW) or #1 aluminum ( USE or THHW)
if direct burial- 24"
rigid metal conduit- 6 "
PVC conduit- 18"
Old 03-01-2008, 06:41 PM   #4
Thanks for that input, it helps a lot!!!
Old 03-01-2008, 07:23 PM   #5
nap
You talking to me?
nap's Avatar
Do not forget you must have a main breaker panel or use a disconnect. You also will need a grounding electrode system and that now includes tying to the rebar in the foundation.
It helps to install a conduit through the forms when pouring the footer. Be sure to bring that up through the floor before you pour the floor.
Oh, and don't even bother with anything other than a 4 wire feed. A 3 wire may still be legal in your area (2005 code- ok, 2008 code-not) but it is simply less hassle to simply put the 4 wire in to start with.
Old 03-01-2008, 08:19 PM   #6
That is great info! I plan on a deep footer and havent planed on rebar in the foundation. The footer is going to be at least 30" deep and 1' wide all the way around the garage with the floor poured inside of that seperately. Plans are subject to change if needed. I am still learning how to do it the right way.
Old 03-01-2008, 08:32 PM   #7
Also, when I get to wiring the light/outlets should I use 12-2 with ground or 14-2 with ground?
Old 03-01-2008, 08:35 PM   #8
Res Ipsa Loquitur
For residential I use 14-2wg for lights and 12-2wg for receptacles but in a garage I would probably just go with all 12-2.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-01-2008, 08:41 PM   #9
That is what I was thinking.
Old 03-01-2008, 08:42 PM   #10
Union Electrician
goose134's Avatar
Brick garages are sweet.
Another thing to remember is that the largest size panel you can put in your garage is a function of the size of your main.
goose134 is offline   Reply With Quote
Old 03-01-2008, 08:50 PM   #11
I think that a 100 amp box is plenty for my garage. I bought a Square D Home line 100 amp box with main and 5 breakers today. I dont need it for awhile but it was on sale for 50 bucks. I like the square d's. I replaced my old Federal Pacific box in my house last year with a square d.
Old 03-02-2008, 02:50 AM   #12
" Euro " electrician
frenchelectrican's Avatar
the other thing if you are on 08 code cycle you have everything in the garage to be GFCI'ed that including the lighting circuit and Garage door opener.
the 240 volts equiment is not need a GFCI unless the manufacter required for it. [ i doubt it but only one i know they do use the GFCI on 240 v unit is pressure washer that is the item i know of.]
Merci, Marc
Old 03-02-2008, 02:28 PM   #13
PVC conduit- 18"
What way should I go copper or aluminum? Should I use conduit, if so what size?
Old 03-03-2008, 06:47 PM   #14
Anyone have any preferences? Conduit is on sale this week and I am thinking plastic. Just because it sounds easier to work with. Copper or aluminum?
Old 03-03-2008, 08:24 PM   #15
Check with local codes.
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
