New Furnace, Code Compliance? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-23-2008, 09:18 PM   #16
Rewards Points: 508
Send a message via AIM to theatretch85
So I have decided to go ahead and at least wire in a new separate circuit for the furnace and re-wiring of the main panel (its a mess). I am also considering running a 20 amp 12 gauge run for just the bathroom outlets downstairs. Can this 20 amp circuit for the basement bath outlets (lights will stay on another circuit as those are all wired up with 14/2) also be used for the upstairs bathroom outlet while those lights are also on a separate circuit? So essentially the outlets only of two bathrooms to share the same 20 amp circuit. Currently, the entire upstairs bathroom (lights and outlets) are on its own separate 15amp circuit (which is a plus from the way it was wired before).
I think at this point it would be pointless to upgrade to a 200 amp service and panel, though it would be better to have a bigger main panel. Most of the wires have been kept a little long in the panel, so an upgrade to a bigger panel wouldn't be that hard later on.
I have figured out a way to add some extra circuits to the main panel by moving the double pole breaker that feeds the sub panel to a spot that doesn't accept the 1/2" breakers. Then I should have enough spaces to do what I need/want to do in terms of the new circuits.
theatretch85 is offline   Reply With Quote
Old 12-23-2008, 09:31 PM   #17
Rewards Points: 2,350
Absolutely.
Carrier furnace help code 13 mudtruck HVAC 10 11-23-2013 02:24 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
