Old 02-22-2004, 03:55 PM   #1
Unregistered
Guest
Posts: n/a
New fixture wiring question
Hi,
I am trying to install a new chandelier and do not have good instructions about how to connect the wires. In the electrical box, there is a black wire, a white wire and a bare wire. Coming out of the fixture, the wires are not black or white - so I don't know which to connect to the wires in the electrical box. Two of the wires appear to be identical - bundles of small silvery wires. These two bundles are encased in clear plastic. The third wire is a bare silvery wire, which I assume is a grounding wire. Can anyone help me determine how to properly connect everything?
Also, about the grounding - on the mounting plate, there is a green screw. Should I connect the grounding wire from the electrical box and from the fixture to this screw?
Thank you!
Old 02-22-2004, 08:34 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Ground is ground, you got that correct. Yes, do hit the bar and the wire.
The others are; smooth wires to the black and ribbed wires to the white. One wire will have tiny ribs along the length.
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
light fixture wiring jasjks Electrical 4 11-29-2006 03:51 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
