-   -   New fixture wiring question (http://www.diychatroom.com/f18/new-fixture-wiring-question-109/)
Unregistered 02-22-2004 03:55 PM
Hi,
I am trying to install a new chandelier and do not have good instructions about how to connect the wires. In the electrical box, there is a black wire, a white wire and a bare wire. Coming out of the fixture, the wires are not black or white - so I don't know which to connect to the wires in the electrical box. Two of the wires appear to be identical - bundles of small silvery wires. These two bundles are encased in clear plastic. The third wire is a bare silvery wire, which I assume is a grounding wire. Can anyone help me determine how to properly connect everything?
Also, about the grounding - on the mounting plate, there is a green screw. Should I connect the grounding wire from the electrical box and from the fixture to this screw?
Thank you!
Speedy Petey 02-22-2004 08:34 PM
Ground is ground, you got that correct. Yes, do hit the bar and the wire.
The others are; smooth wires to the black and ribbed wires to the white. One wire will have tiny ribs along the length.
