New Exhaust Fan Install In A Old Bathroom? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2007, 01:43 PM   #1
New exhaust fan install in a old bathroom?
I am trying to install a exhaust fan in our bathroom. The room never had a fan before. I need to know how to wire the fan to an existing wall switch.
Thanks for the help.
tom6024 is offline   Reply With Quote
Old 03-08-2007, 01:53 PM   #2
Rewards Points: 150
Confusion time. If there never was a fan, how could there be a switch?
Just kidding...Anyway, I assume you want to attach it to the light switch so the fan comes one with the light. Is that correct? Pick your poison. Either run the wire down to the switch and pigtail them together or run the wire to the fixture and make the connection there.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 03-08-2007, 03:25 PM   #3
Dear Mr. Beer Geek,
I would like to change the single light switch to a double switch so as to turn them on independly.
Old 03-08-2007, 05:11 PM   #4
Rewards Points: 150
It depends on how the light is wired. How are the wires connected to the switch and the light? How old is the house? I ask these questions in order to determine how to phrase an answer. I'm sure the pros would need more information as well.
Old 03-08-2007, 05:31 PM   #5
Where is the existing light? Are you trying to replace a ceiling light with a fan light combo?
Is there an attic? Above the bath room?
Master Electrician
jwhite is offline   Reply With Quote
Old 03-09-2007, 07:27 AM   #6
The light switch is on the out side of the shower wall and controls the light in the shower. The light switch is a single pole ,single throw switch. I thought I could install the fan and drop a wire from the attic to the wall switch and change the switch to double pole, double throw switch. I then could operate the light and the fan independent of each other.
Old 03-09-2007, 08:19 AM   #7
Rewards Points: 150
That's fine but it doesn't tell us how it's wired. Is the switch at the beginning or end of the run? Secondly, you want 2 single pole switches if you want them to act independently.
Old 03-09-2007, 09:54 AM   #8
I now understand what you are asking . I don't know the answer to that question and I don't know how to tell.
Old 03-09-2007, 12:09 PM   #9
Rewards Points: 150
I'll ask one more question but I'm really leaning towards you having a pro come in and take care of this.
When you turn off the power and pull out the switch, what do you see?
Old 03-12-2007, 07:28 AM   #10
I pulled the switch out and there were two wires coming down in to the box. All the grounds were tied together, all the whites were tied together and there was a black on the top and bottom of the switch. The switch had only two screws on it.
Old 03-12-2007, 10:01 AM   #11
Rewards Points: 150
That's great information. The first thing I'd do, is go out and get the Black and Decker Advanced Home Wiring Book. It has simple diagrams for you to follow.
Page 28 shows Ganged Single-pole Switches Controlling Separate Light Fixtures.
It is exactly what you are looking to do. I could write paragraphs describing the connections but the picture really makes it easier.
Follow this link: http://books.google.com/books?id=TAK...Za__s#PPA28,M1
It is the page in the book that you want. Hope this helps.
Old 03-12-2007, 11:32 AM   #12
Mr. Beer Geek
Thank you so much for your help, but most important for your time to help. Thanks again
bathroom exhaust maintenance HVAC 14 12-10-2007 07:27 AM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 08:59 AM
Bathroom exhaust question Horace HVAC 4 07-27-2006 08:54 AM
Bathroom exhaust problems HomeRepairNoob HVAC 9 04-18-2006 10:33 AM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 10:45 PM
