New Entrance Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 08:34 AM   #1
New Entrance Panel
Hello All. I am going to install a new 200a panel in my furnace room. Problem is that it is on a different area of the house. My plan is to bring the cable into the house through the attic and down through the wall into the panel top in conduit (metal?) (pvc?). The distance would be about 25 feet. I used to work in a factory in maintenance department, sometimes with the electrician and this is done all the time, using metal conduit. From my reading however it is suggested that this is not acceptable. Any help and suggestions would be appreciated. Thanks.
fairview887 is offline   Reply With Quote
Old 08-06-2011, 09:34 AM   #2
Lic Elect/Inspector/CPO
You can use emt or pvc. I would use pvc and the cable needs to be 4 wire.
NJMarine is offline   Reply With Quote
Old 08-06-2011, 09:43 AM   #3
I=E/R
a7ecorsair's Avatar
Will this new panel be fed from something that has a disconnect?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
J. V. (08-06-2011)
Old 08-06-2011, 12:36 PM   #4
Rewards Points: 58
Not true.
If this is a service and not a feeder it can be three wire. We have no idea as the OP has not told us what he has outside his house as far as meter, disconnect or meter main.
If he only has a meter it would be a service all the way to the panel. Then only a three wire cable would be required.
Old 08-06-2011, 01:01 PM   #5
Master Electrician
Rewards Points: 3,678
Originally Posted by J. V. View Post
Not true.
Not for 25' inside the house.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
NJMarine (08-06-2011)
Old 08-06-2011, 02:01 PM   #6
Missouri Bound's Avatar
If it doesn't, it can't be run inside the house. (for any distance)
Old 08-06-2011, 05:11 PM   #7
wareagle's Avatar
JV
I thiink njmarine is referring to the run from the new 200 amp panel to the existing panel. If so, it needs to be 4 wire. How about something like this
http://www.southwire.com/ProductCata...prodcatsheet66
wareagle is offline   Reply With Quote
Old 08-06-2011, 07:06 PM   #8
Electrical Contractor
kbsparky's Avatar
Originally Posted by wareagle View Post
JV... How about something like this
That MC cable would not be suitable for a 200 Amp panel, the largest it was offered is #2. Way too small for a 200 Amp feeder.
-KB
Old 08-06-2011, 07:13 PM   #9
wareagle's Avatar
I was thinking the OP needed a run from the 200 amp panel to the old panel. My error.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 03:05 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
