Old 04-03-2007, 11:58 AM   #1
I have gas!
Clutchcargo's Avatar
New electrical in renovation
I doing a renovation on my house and I plan on rewiring everything. I have about 2/3s of the house down to studs and am living in the last 1/3. Currently there is only 1 outlet/room so my plan is to overkill and put an outlet every 6 feet and have each room on its own breaker.
The second floor will have a total of 6 circuits.
Bathroom 2-20A GFCI & 1-15A
Bedrooms 3-15A AFCI, I'm going to power the entry way interior/exterior lights, and smokes with the smallest-bedroom circuit.
Does this sound reasonable?
It's a relatively small house so I plan on using 2x3s on nonstructural walls to gain an extra inch of living space. When I run electrical through the 2x3 walls do I need a nailing plate on both sides? Is there going to be a problem fitting boxes in these walls?
Am I allowed to add 2 outlets in the same stud bay on each side of a shared wall?
Does it matter what height the holes are for the wires in the studs? I was thinking around 2' so that I can keep it consistent throughout the house, be able to clear windows, and I think this is an area least likely to be nailed with picture hangers and such.
When adding wire in insulated walls, should I go through the insulation or on top of the vapor barrier?
Finally, for now, the panel is in the basement and is on the side of the house that is not demo'ed yet. I need to find a way to get from the cellar to the second floor. The wall that currently contains the existing wires is planned for demolition so following those wires up won't work. Is there anything I should look for or look out for? Can I run the wires next to the chimney?
TIA
Cliff
Clutchcargo is offline   Reply With Quote
Old 04-04-2007, 08:43 PM   #2
I have gas!
TTT
Any ideas?
Old 04-05-2007, 11:32 AM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I'm not a pro but I'll take a stab at your questions....
Check with wife, if you have one, I did something similar and aesthetically its not the greatest.
yes
OK
Its a good idea if this wall will be finished both sides. maybe not a requirement but better safe than sorry.
No. Personally I like to use the largest box possible, makes things easier.
Yes, back to back may be impossible with 2x3 walls though.
No - If 2' is convenient for you then go for it. I go about 12" above my boxes so I can staple within 6" or so of the box. I snap chalk line so all my holes line up. It makes pulling wire easier.
yup
Through the insulation. Actually you wire first then insulate. if using batts you can split them so insulatin is behind and in front.
Sounds like you want to find an easy chase from new work to elec panel. Not sure about chimney. Fire blocking may be a concern as well as securing the wires. If you need to demo a little more to have a decent, easy to navigate, wire chase I would do it now.
TIA
Cliff
NP
I didn't give any thought to things you may have missed in your plan. Nothing jumps out as really bad. Good luck.
Brik is offline   Reply With Quote
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
Subpanel Questions/Running electrical to garage. FlyGuy Electrical 28 05-24-2008 11:50 PM
Electrical continuity Tool Rze Electrical 11 10-01-2006 05:10 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 09:46 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
