New Electric Services For Duplex. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 07:03 PM   #1
New electric services for duplex.
Hoping somebody can help me out here.
My family owns a duplex (rental property) that has two old 60 amp. fuseboxes that feed each unit.
I was planning on replacing these with 100 amp. breaker boxes , and a new double meter base, however the supplier that I bought these from gave me only 100 amp. entrance cable.
Shouldn't the cable from the weatherhead to the meter base be 200 amp. entrance cable? And 100 amp. from each meter to each panel?
Thanks, Jimmerz
jimmerz is offline   Reply With Quote
Old 12-04-2012, 08:22 PM   #2
Rewards Points: 1,192
Service cable can be sized by computed load.!00 amp cable is probably too small to feed the meter base.
bobelectric is offline   Reply With Quote
Old 12-04-2012, 08:36 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,600
I dont think that the minimum size of cable is mandated !
It is really up to the instaler to size appropriatily.
How ever 100a seems a bit low for 2 units,
So I would go for 200a.
dmxtothemax is online now   Reply With Quote
Old 12-05-2012, 06:40 PM   #4
Thanks guys!
Kinda what I figured.... Being as each panel could potentially draw 100 amps before blowing the main breaker, 100 x 2 = 200 amp. cable to feed the meter can. Neither unit will draw more than 100 amps. , probably at most 80 amps.
Old 12-05-2012, 07:53 PM   #5
Licensed electrician
Rewards Points: 1,870
A load calculation is the proper way to size the service and cables.
Old 12-05-2012, 07:59 PM   #6
TTW
TTW's Avatar
What actual size wire did you get?
TTW is offline   Reply With Quote
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
Converting duplex to single family--what to do with electric services? zamoti Electrical 32 01-29-2009 03:16 PM
