New Electric Oven: Need Help Connecting Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 10:54 AM   #1
New electric oven: need help connecting wires
First off, let me say I'm experienced with electrical circuits, wiring, and working on appliances. I'm not a licensed electrician but definitely not an amateur DIY either.
We just got a new electric oven to replace our old one. The wiring is 3-wire with each wire looking about 6awg. My problem is I cannot get the wires into their holes on the electrical "panel" on the back of the new oven. It looks like the holes are meant for 8awg. I know I can use connectors instead to secure the wires to their respective places but what type of connectors do I need to use? Would set screw lugs be ok? Thank you.
Tony
TonyS is offline   Reply With Quote
Old 08-09-2009, 11:58 AM   #2
dSilanskas's Avatar
Tony
And you can't figure it out?v
dSilanskas is offline   Reply With Quote
Old 08-09-2009, 12:22 PM   #3
Journeyman Wireman
Rewards Points: 150
I think this is a valid question. How about a picture of the terminations at the appliance with the wire nearby for a reference? We could then discuss the merits ways to terminate the wire.
Jupe Blue is offline   Reply With Quote
Old 08-09-2009, 01:53 PM   #4
Thanks Jupe Blue. Here's a picture of what I'm working with:
Yes, I've removed the set screws from the three terminal blocks.
New electric oven: need help connecting wires-oven.jpg
Old 08-09-2009, 02:17 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
The oven is not made to be hardwired.
Those connections are made for a spade connector from a cord used to plug into a receptacle.
No matter what you try, you will never get that #6 connected to those screws!
Old 08-09-2009, 02:26 PM   #6
300zx's Avatar
Post
Yes you need a cord..
300zx is offline   Reply With Quote
Old 08-09-2009, 02:27 PM   #7
Well, there are holes on the underside of the terminal blocks meant for hardwiring, and the directions also indicate this.
Old 08-09-2009, 02:29 PM   #8
Gotcha. I figured we could add a receptacle. My buddy's a licensed electrician but he's away on vacation for the next 2 weeks. It figures...
Old 08-09-2009, 02:39 PM   #9
Rewards Points: 2,350
It is astonishing how many people have "licensed electrician" friends, or are going to have a "licensed electrician do the hook up", but just want to ask a few questions here, to be sure.
Old 08-09-2009, 02:49 PM   #10
You know what's astonishing is how fast people jump to conclusions.
Thanks everyone for your help. Since I can't wait 2 weeks for my buddy to return I'm going to hire an electrician to come over and do what needs to be done.
Old 08-09-2009, 02:52 PM   #11
No, no. Don't take it that way. Your statement just made me think of it so I quoted you. I have read several posts here in the last couple days where a similar statement was made.
And, if you have some electrical experience, you could easily put the receptacle in yourself. And save a heap of money. A surface mount 3-wire range receptacle is less than $10, and the cord is maybe $12.
Old 08-09-2009, 03:05 PM   #12
Then I apologize for misunderstanding you. I really try NOT to be one of those "oh, I can do it" guys that have no real experience/knowledge. That only gets you into trouble quickly. I hate to say it because I know this is also a cliched statement, but I know my limits.
Well, we lucked out. I spoke to my buddy's sister and she has one of their licensed electrician employees coming over tomorrow to take care of it. I could do it but since they'll be cutting me a $ break I'd rather have him do it. Thanks again folks for the replies.
Old 08-09-2009, 03:07 PM   #13
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Tony
If this is an oven and not a range it likely doesn't need 6 awg for its branch circuit and those wires may indeed be to large in awg to fit the terminal block for hard wiring... . You could use a range cord but I'd get the flat 40 amp gray type. The black round type are very bulky and I don't think it will work based on what I see in your picture. I'm thinking the preferred way to wire your oven is by hardwiring so you could install a jb and run a appliance whip to the oven.
What are the electrical requirements for the branch circuit for your oven...?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-09-2009, 04:10 PM   #14
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I'd check with the appliance store. I never heard of having to wire my own oven, they usually come with the proper cord attached.
Old 08-09-2009, 06:30 PM   #15
"Mystery" of old leads not fitting on new oven
Originally Posted by Stubbie View Post
Tony
As you point out in the last paragraph. "What are the electrical requirements...."! People sometimes tend to forget the basics. But in any case. If the picture in post #4 is a true representation of the condition of the leads, they'll never fit into the Lugs, or whatever termination there is on the (back) panel. They're all spread out. (Now more than ever)Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Req: Help connecting circuit breaker and running wires RickDel Electrical 5 05-26-2009 06:38 PM
Normal Amp of Electric Oven (oven only no cook top) jamiedolan Electrical 4 02-11-2009 11:46 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 01:11 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
