New Dryer Is 3 Wire, Receptacle Is 4 Wire. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 10:31 AM   #16
Originally Posted by Gigs View Post
Why would it be this way in a dryer that was 120/240 and shocking him?!
Obviously this is a fault.
Loose neutral?
rgsgww is offline   Reply With Quote
Old 01-12-2009, 11:32 AM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
As inphase said 3 wire dryers are frame bonded to neutral as shown below...... My understanding is he used his ground wire in the 4 wire supply as his neutral and capped the white neutral wire to have a 3 wire connection . Assuming he wired the terminal block correct his dryer should work normally without being shocked. He is just using the wrong wire but the dryer doesn't know that....
The fact that he was getting shocked does suggest that something is not quite right. Normally the big problem with 3 wire dryers is they are right next the washing machine. If you have a bad neutral connection at the dryer or an open neutral and touching the washing machine at the same time as the dryer you provide a path for the dryer neutral current back (thru you) to the source via the ground of the washing machine because the dryer frame is bonded to the neutral at the terminal block. It would also be possible to get shocked it the bonding jumper connection is open or bad on three wire connections of dryers and he has a fault to a hot wire.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-12-2009, 11:39 PM   #18
DIYer
My confusion comes from the dryer being intended for 4 wire and having circuits that require it, but still having a place to put a grounding strap. Oh well he said he got it sorted now, so it's all academic.
Gigs is offline   Reply With Quote
Old 01-13-2009, 08:37 AM   #19
UAW SKILLED TRADES
Stubbie's Avatar
A dryer is not intended to be 4 wire they come new in the box usually wired for 3 wire connections and can be converted to 4 wire by removing the bonding strap. So the point is they can be either 3 or 4 depending on your supply branch circuit..
Stubbie
Old 01-13-2009, 09:03 AM   #20
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
True because I do believe that there is a code that it must be installed accoridng to the manufacturer. Not sure though does anyone know for sure?
I believe that the new code states that it must be done by a 4 wire connection. I will look it up at tech today and try to understand it.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Old 01-13-2009, 09:16 AM   #21
Rewards Points: 2,350
A new supply circuit must be 4-wire by Code. But the manufacturer of the dryer can send it anyway they want.
Old 01-13-2009, 09:45 AM   #22
UAW SKILLED TRADES
Stubbie's Avatar
I suppose I should clarify. If the branch circuit is existing and is 3 wire and that 3 wire meets the requirements of NEC 250.140 the appliance can be connected to the existing branch circuit. If you are running a new branch circuit or replacing an existing 3 wire branch circuit it must be a 4 wire supply to the appliance.
Stubbie
Old 01-15-2009, 09:59 AM   #23
Pudge565's Avatar
Rewards Points: 150
Ok thank you for clearing that up for me and helping me understand.
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 01:07 PM
how to wire romex to 2 3 ways to a half hot receptacle smoothinstall Electrical 3 11-30-2008 10:56 PM
Should a dryer be 10 gauge wire & range 8/3? twilightcall Electrical 7 07-03-2008 06:29 AM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Wiring a 220v dryer receptacle pjpjpjpj Electrical 8 06-05-2007 04:08 PM
