New Doorbell Transforming Overheating... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 12:23 AM   #1
New doorbell transforming overheating...
Why is my new doorbell transformer hot or overheating. The new transformers is a variable type. It has three wires, one black, one white and one green. I connected it color for color simple right!!! After hooking it up, I also tested it for proper operating voltages, and it tested ok it ranged from 10v to 26v. The doorbell button and chime are disconnected I don't get it. I did mine at my house and everything went smoothly. Please help!!!
mvazquez74 is offline   Reply With Quote
Old 06-26-2011, 12:56 AM   #2
Rewards Points: 1,192
Not to dis you ,but xfmrs always feel hot in service.What is hot to people is normal to transformers.
bobelectric is offline   Reply With Quote
Old 06-26-2011, 01:11 AM   #3
dmxtothemax's Avatar
Rewards Points: 5,506
Yes quite true !
temps of 40 to 50 degrees celsius is normal.
So how hot are we talking ?
If it is just stinking hot,
then there may be shorted turns,
But normally transformers do run quite warm,
almost hot.
dmxtothemax is online now   Reply With Quote
Old 06-26-2011, 01:15 AM   #4
I'm just worried that it may catch on fire. When I did the installation on mine at home. I connected the black and white wires only to the transformer, and left the ground disconnected because there's no ground wire there in the box to connect it to. I replaced everything, button, transformer and chime. And everything is fine, but when I went over to my cousins house to try to replicate this it's not having it. My transformer is cool to the touch and his is extremely hot...
Old 06-26-2011, 01:27 AM   #5
NACE Coating Inspector
mustangmike3789's Avatar
did you check to see if you have some jahovah witness guys waiting on you to answer the door?
mustangmike3789 is offline   Reply With Quote
Old 06-26-2011, 08:06 AM   #6
I=E/R
a7ecorsair's Avatar
Are both transformers variable?
The output voltage reads good, did you check the input side? Just to make sure the connection is correct, measure the input side for 120V.
a7ecorsair is offline   Reply With Quote
Old 06-26-2011, 08:52 AM   #7
You'd know within seconds if the voltage was wrong!
Old 06-26-2011, 09:05 AM   #8
I=E/R
a7ecorsair's Avatar
You and I know this but to lay out a troubleshooting path, it has to be done. What if.... it is connected to an unbalanced MWBC?
Old 06-26-2011, 12:46 PM   #9
I checked the input before I installed the transformer, and it read 120v. I noticed the wires that connect to the transformer are located on the other side of the main breaker box is that ok????
Old 06-26-2011, 08:41 PM   #10
Rewards Points: 1,538
One of the doorbell buttons may be stuck. Doorbell transofmers should not be running current except for the brief moments that someone is pushing a button.
Old 06-26-2011, 09:42 PM   #11
I=E/R
a7ecorsair's Avatar
I don't know exactly what you mean by other side of breaker box.
It is entirely possible the transformer is defect. When you say the button and chime are disconnected, do you mean there are no wires connected to the low voltage side of the transformer?
Old 06-26-2011, 09:53 PM   #12
Semi-Pro Electro-Geek
Rewards Points: 2,970
Before you go chasing a phantom problem, confirm that you actually have a problem. As many have already said, transformers get hot. Even with no load connected at all, it may get almost too hot to touch. How do you know it's hotter than it's supposed to be?
mpoulton is offline   Reply With Quote
Old 06-26-2011, 11:02 PM   #13
Yeah nothing is connected to the low voltage side. The only thing connected is the transformer!!!
Old 06-27-2011, 01:43 AM   #14
Transformers still use some current with no load connected (it's called the "magnetizing current"), and thus get hot. The more compact and cheap the transformer, the greater the heating from magnetizing current.
Old 06-27-2011, 06:39 AM   #15
I am led to believe that a transformer that gets too hot to touch is so cheap that it will not last very long and has a good chance of becoming a fire hazard.
Doorbell Diode hindelicato Electrical 15 10-30-2010 10:52 PM
Doorbell Question captainron19 Electrical 21 03-05-2010 04:40 PM
Doorbell Transformer fpeikin Electrical 14 11-30-2009 06:19 PM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 12:53 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
