New Doorbell - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 11:24 PM   #1
Rewards Points: 115
New Doorbell
I'm about to replace my doorbell do i need a new transformer or can i just reuse the one that's there? Also are doorbells hard to replace?
texasman21 is offline   Reply With Quote
Old 04-12-2013, 11:57 PM   #2
joed's Avatar
Rewards Points: 11,506
If the transformer is good and the proper rating you can reuse it.
Old 04-13-2013, 01:15 AM   #3
Rewards Points: 115
Does it say anywhere on the transformer its rating? Or is it just easier to get a new one.
Old 04-13-2013, 01:19 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Most common resdential doorbell unit I know useally are at 16 volts however let me warn ya do not get mixed up with HVAC transfomer both look simauir but the voltage rating is differnt ( typically 24 volts )
If you do have DVM set it on the AC volt scale it should read about 15-18 volt range then it is a doorbell transfomer. There are some other voltage it used on doorbell system which it is 6, 8 or 12 or 16 some case 24 volts but 16 is the most common one.
Most of the time the doorbell unit is not super hard to replace but make a note of it what it connected like common ( some case transfomer ) then it will marked front and rear so pay attetion to them before you unhook and take a peice of tape and mark it down so it will save yourself alot of headache and time.
Merci,
Marc
Old 04-13-2013, 01:28 AM   #5
Rewards Points: 115
Where is the transformer usually located in the house cause i figured with the doorbell unit on the wall.
Old 04-13-2013, 01:37 AM   #6
It will varies alot but most case useally near the breaker / fuse box and if you have basement that will be the next spot you will find them.
But once a while I will find them in attached garage or in attic ( useally not the best spot for the doorbell transfomer due the attic tempture can kill them )
Merci,
Marc
Old 04-13-2013, 04:14 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 766
Ya know.....I'm becoming a real fan of the wireless door bell units....considering that ours is pressed maybe 3 times a year...after about 8 years, our original wireless battery powered door bell is still dinging....
The actual 'dinger' is one of those types that also acts as a wall feature....you can put stuff on it....my wife has lots of 'stuff'....and likes to move the 'stuff' around....so...it's easy for her to move the 'stuff'.....stuff that is not tied to a physical wire.....
Yea...I like battery powered wireless...
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (04-13-2013)
Old 04-13-2013, 10:52 AM   #8
Rewards Points: 1,192
Usually,the hvac xfmr would be inside the inside air handler,so don't look in there.
bobelectric is offline   Reply With Quote
Old 04-13-2013, 11:24 AM   #9
joed's Avatar
Not usually. Often found right at the panel. Sometimes found on light fixture box in the attic.
Locating Doorbell Transformer RodC Electrical 13 11-13-2012 07:00 PM
Converting a wired to a wireless doorbell ohman Electrical 12 10-22-2012 11:20 AM
Problem with wire to doorbell button. darsunt Electrical 7 03-04-2012 09:40 AM
Troubleshooting this doorbell darsunt Electrical 14 09-20-2011 01:02 PM
Doorbell Question captainron19 Electrical 21 03-05-2010 05:40 PM
