New Cooktop Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2008, 09:52 AM   #1
New Cooktop question
I was reading the instructions for my new Jenn-air cooktop and it requires 240V and a 40amp breaker. I checked my panel and see that my current cooktop only uses a 30amp breaker on 240V. I can put in a new breaker, but do I need heavier wire or will I be okay? The house was built in 1986 in the burbs of Chicago. I assume I just need a new breaker, but you know what they say about "assume".
Thanks,
Matt
drcoffee is offline   Reply With Quote
Old 03-30-2008, 10:42 AM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
We install a certain size wire to serve a particular load. Then we install a certain size circuit breaker to protect that size wire. So I am going to assume your wire is number 10. Good for 30 amps. Number 8 wire is required for a 40 amp circuit. So you cannot just change the circuit breaker without also changing the wire.
jrclen is offline   Reply With Quote
Old 03-30-2008, 10:54 AM   #3
Electrician
But just to be sure, check out the existing wire and tell us what AWG it says...
chris75 is offline   Reply With Quote
Old 03-30-2008, 10:54 AM   #4
That makes sense. Is it difficult to pull 8ga wire. How would you suggest I to swap it out?
Old 03-30-2008, 10:55 AM   #5
Electrician
first look at the existing wire and verify what size it is...
Old 03-30-2008, 11:28 AM   #6
The wire is stranded 10ga
Old 03-30-2008, 12:13 PM   #7
" Euro " electrician
frenchelectrican's Avatar
to OP sound like you are near chicago so therefore if so check the pipe where the cooktop goes it should be 3/4 inch emt pipe if so you are in luck but you may have to follow the path to see if there is no junction box in the middle of run i know it will show up one way or other so check it first before you yank the wire out.
once you see it clear to pull just tie new wire to the old one and guide it you will get there pretty fast with short run otherwise get a fishtape and pull the new wire after ya yank the old wire out.
IF this in NM romex then it get little more trickier let us know.
Merci,Marc
Old 03-30-2008, 01:43 PM   #8
Rewards Points: 150
Get a licensed electrician to perform this task.
JGarth is offline   Reply With Quote
Old 03-30-2008, 02:05 PM   #9
Merci,Marc
There is a junction box 10 feet from the stove that looks to be where the double oven and stove split off. There's no romex, it's all hard conduit with individual wires. I'll have to check again, but from what I recall, the conduit looked pretty full leaving the breaker box.
Old 03-31-2008, 08:38 AM   #10
Is it alright to run a new line from the breaker box to the stove with BX 08-3 wire? Do they make it that large? Does it need to be in solid conduit? As a DIY project that would be the easiest but does it comply with code?
Old 03-31-2008, 03:59 PM   #11
Way too many question that need to be asked/answered on this one.
If I were doing it and there was a conduit path back to the panel, I would do everything I could to use it.
With the proper technique there is always enough room
Pics are always good.
220/221 is offline   Reply With Quote
Old 03-31-2008, 04:51 PM   #12
I've just called my electrician to come and pull the line. I appreciate everyones help.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
need help with a new cooktop m_shel Electrical 9 02-08-2008 10:56 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
