New Construction: Wire Exiting Wall, No Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 07:51 PM   #1
New Construction: wire exiting wall, no box?
When you're doing rough-in wiring for the dishwasher and garbage disposal that will be direct wired, how do you leave the cable for the drywallers? Do you just attach it to a stud with a bit hanging out and rest curled up in the wall cavity? Thanks...
Roaddoggie is offline   Reply With Quote
Old 11-11-2010, 07:59 PM   #2
I usually tack a staple loosely to the plate so this way the hacks, um I mean drywallers dont move it around on me.
lordlondis is offline   Reply With Quote
Old 11-11-2010, 08:17 PM   #3
Rewards Points: 150
I put it in a box.
When it comes time for final installation, make a "whip" out of flexible conduit of your choice. Attach one end to the appliance and the other to one of those blank plates with a center knockout, using appropriate clamps/connectors.
emolatur is offline   Reply With Quote
Old 11-11-2010, 08:29 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I never use direct wiring for a garbage disposer. A power cord installation is much cleaner under the sink and makes servicing a snap
http://www.acehardware.com/product/i...ductId=1276688
New Construction: wire exiting wall, no box?-power-cord-gd.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-11-2010, 08:35 PM   #5
Do NOT curl it up int he wall cavity, the drywallers will go right over it. Staple it as close to the face of the stud as possible in the position you want it to exit the drywall, then loosely curl it up with it sticking into the room so that the drywallers know where it comes out and can uncoil it and pull it thru a hole in the drywall as they install it.
Lockeset is offline   Reply With Quote
Run wire to Breezeway through brick and up brick wall wad2k Electrical 0 04-16-2010 08:18 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Running a wire through the wall RegeSullivan Electrical 1 09-27-2009 08:28 AM
Wire closet shelf coming out of wall... Iluv4cats General DIY Discussions 16 01-15-2009 05:39 AM
V shaped wall construction brosnt1 Building & Construction 3 02-08-2006 02:00 PM
