Old 10-24-2011, 12:56 PM   #1
New Construction or Remodel Recessed Housings?
I am starting a recessed lighting project where I will have attic access. Given that I can use either new construction or recessed housings, my question is which one you guys recommend. Assuming the cost for them is the same, is one easier to install than the other? Or are there any other drawbacks to either? If it matters, I have batt insulation in the attic so the housings will be IC. Thanks in advance.
chewbakarox is offline   Reply With Quote
Old 10-24-2011, 01:03 PM   #2
Super Moderator
I would probably use remodeling cans---that way most of the work is done from a nice clean ladder instead of face down in the insulation----That's me---let's see what others have to say----Mike---
oh'mike is online now   Reply With Quote
Old 10-24-2011, 01:10 PM   #3
liscenced electrician
i hate remodel cans. I always choose new construction if there is access. Although the other day i chose remodel cans because i would have been army crawling through knee deep blown in insulation.
jimmy21 is offline   Reply With Quote
Old 10-24-2011, 02:09 PM   #4
I used new construction cans when I installed the recessed lighting in my living room. The insulation in the attic was a bit of a bear, but at least I could see what I was doing.
clashley is offline   Reply With Quote
Old 10-24-2011, 02:19 PM   #5
I prefer to be able to nail my can lights into the framing rather than relying sheetrock. Also, your wiring should be secured anyway if it is accessible, so your not really saving any time by using remodel cans.
Energy Efficient Recessed Housings chewbakarox Electrical 7 09-27-2011 12:16 PM
Quality of USA Light Recessed Housings BPC Electrical 0 08-10-2011 05:57 PM
Installing remodel recessed lights in manufactured home. MikeVila Electrical 14 08-03-2011 08:06 AM
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 10:25 PM
What brands should I avoid in selecting housings for recessed lights dennisjow Electrical 4 08-11-2007 07:54 PM
