New Construction Blue Plastic Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 09:19 PM   #1
Rewards Points: 1,062
Question
new construction blue plastic boxes
do you not need to use anything equivalent to clamp connectors with these new construction blue plastic receptacles that have some sort of tabs in the back through which to pull the cable? i was thinking the tab stop the cable in case it gets pulled out, therefore doing what the clamp connector does.
Old 05-16-2011, 09:27 PM   #2
Missouri Bound's Avatar
You just need to fasten the wire within 6 inches of the box...staple to a stud.
The Following User Says Thank You to Missouri Bound For This Useful Post:
amakarevic (05-16-2011)
Old 05-16-2011, 10:31 PM   #3
Electrical Contractor
kbsparky's Avatar
Code allows within 8 inches ....
-KB
Old 05-16-2011, 10:42 PM   #4
I=E/R
a7ecorsair's Avatar
I think you will see that the single gang boxes don't even have the lock tab
a7ecorsair is offline   Reply With Quote
Old 05-16-2011, 10:45 PM   #5
KB..thanks for the clarification....I was too lazy to look it up.
Old 05-17-2011, 01:21 AM   #6
" Euro " electrician
frenchelectrican's Avatar
Only on the new work single gang box most of them do not have locking tab at all but for remodel or old work box Oui they do have them.
For two gang and larger box most case they will have locking tabs in there.{ very few will not have it}
Merci,
Marc
Old 05-17-2011, 12:29 PM   #7
Rewards Points: 58
You're going to be in mess of trouble when the people on this site that do look these things up, get to lazy to help you.
This just bugs the s**t out of me. If you know where to get an answer and can look it up by yourself, why ask here. Verification is one thing I am totally cool with. In fact I encourage people to verify anything they are told.
If you really knew where to look it up I would be surprised.
Old 05-17-2011, 06:30 PM   #8
Electromagician
J V
I love the ones that just tell you it's in the code somewhere. I've even had building officials tell me that, when I knew that it wasn't in the code anywhere. I just respond with, well when you find it let me know the article you are talking about. Of course in this instance at 6" you would at least still be legal, which is much better than just making one up that you think should be in the code.
powerfactor is offline   Reply With Quote
Old 05-17-2011, 08:42 PM   #9
To JV and powerfactor... Sorry if my comment got under your skin. My 6" reference was a safe rule of thumb, within NEC guidlines. And since the comment was taken so poorly I decided to look it up anyway. I can find only one reference and it's 12"..not 6 or 8. So to KB...where did you find the 8" reference?
Or JV....maybe YOU can tell me where to look it up.
Old 05-17-2011, 09:16 PM   #10
Electromagician
Missouri
You didn't get under my skin at all. Been in this business a long time.
by the way 314.16(C) exception
Old 05-19-2011, 06:41 PM   #11
Question
how about running MC cable into a box like that? is it allowed and do i strip the metal cladding before it enters the box or after?
thanks
Old 05-19-2011, 07:10 PM   #12
kbsparky's Avatar
MC cable can not be terminated into a non-metallic box.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
amakarevic (05-19-2011)
Old 05-19-2011, 07:14 PM   #13
shoot !! the only reason i got a plastic box was because that was the only 3-gang box i could find. i need a 3-gang box.
Old 05-19-2011, 07:16 PM   #14
this is what i need but they didn't have it in HD...
http://www.amazon.com/Thomas-Betts-3.../dp/B000HEHFAC
might have to try a special electrical store
Old 05-19-2011, 07:41 PM   #15
Lic Elect/Inspector/CPO
314.3 exception no. 1 allows MC or AC in non-metallic boxes
if it is bonded
exception 2 does permit bonding bushing on all threaded entries,But that would totally change wire fill and be a pain to trim out since there would be a migb for each entry .
So in reality using mc in a plastic box would be a pain,
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
Can I cover unwanted electrical boxes (ie switch box) with drywall?? DanDaMan Electrical 15 03-07-2011 03:59 AM
Are blue boxes required for garage flourescent light fixtures? sheslostcontrol Electrical 11 03-06-2011 07:47 PM
plastic or metal boxes Clutchcargo Electrical 26 10-27-2010 09:07 AM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 06:54 PM
Proper ground with plastic boxes tjandt Electrical 3 11-07-2005 09:16 AM
