New Clamp Meter Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2010, 11:01 PM   #1
Rewards Points: 81
New clamp meter question
I just picked up a new clamp meter today from the supply house. It is a true rms meter and is rated for 600 amps. When I go to test ac voltage the meter displays mv and the numbers jump around when the leads are not touching anything. On my regular open jaw greenlee meter which was alot less expensive when i am testing ac voltage and nothing attached to the probes the display reads zero. Is the meter i bought bad or is this normal?
Chevyman30571 is offline   Reply With Quote
Old 02-18-2010, 11:51 PM   #2
Rewards Points: 81
I just read somewhere that because it is autoranging this occurs. If i short the test leads it zero's out.
Old 02-19-2010, 01:18 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is it an Ideal brand?
Old 02-19-2010, 12:49 PM   #4
The mv likely stands for milivolts. 1 mv = 1/1000th of a volt.
Think of it as the device is attempting to read the tiny voltage potential in the air, which is of course constantly changing.
HooKooDooKu is offline   Reply With Quote
Old 02-19-2010, 06:56 PM   #5
Idiot Emeritus
Rewards Points: 1,492
It's completely normal.
The meter is sensitive enough to pick up stray voltages in the air. That's why it goes to zero when the leads are shorted together.
Rob
micromind is offline   Reply With Quote
Old 02-19-2010, 07:24 PM   #6
nap
You talking to me?
nap's Avatar
I disagree. It just sounds like a crap Ideal meter.
Old 02-19-2010, 07:44 PM   #7
Idiot Emeritus
I should have put 'completely normal for a low-end meter'. lol.
The better ones nave a snubber network to cut back on reading transients.
Rob
Old 02-19-2010, 08:05 PM   #8
nap
You talking to me?
nap's Avatar
Rob
same thing isn't it?
I much prefer Fluke. They've been good to me and for me.
Old 02-20-2010, 12:21 AM   #9
Rewards Points: 81
it is a fluke. LOL, guess it is normal
Old 02-20-2010, 12:54 AM   #10
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Rob
Yep my old meter used to do this. The numbers would get more crazy if I put the probes near a transformer or something. I accidentally set it to amps instead of volts and the receptacle I was testing worked. That was the end of that meter.
Old 02-20-2010, 05:26 PM   #11
nap
You talking to me?
nap's Avatar
Hey, if it works, it's a Fluke!!!
I never could figure out why somebody would name their company Fluke when this is such an easy joke.
Can't say I have ever had the problem with a Fluke.
Old 02-20-2010, 06:50 PM   #12
Have you not seen this furnature store?
www.badcock.com
Old 02-20-2010, 08:01 PM   #13
nap
You talking to me?
nap's Avatar
www.badcock.com
Uh...ya.
Old 02-21-2010, 11:25 AM   #14
Rewards Points: 160
Perfectly normal on Fluke and any other.
Old 02-21-2010, 05:12 PM   #15
Rewards Points: 81
Thanks J.V. Also alot of the guys I work with use ideal clamp meters. Whats wrong with them. Just becuase they didnt want to spend the money doesnt mean that ideal makes bad meters. They are just as accurate as a fluke.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Meter ratings Stubbie Electrical 3 04-02-2008 10:12 PM
Another Neutral/Ground/Bonding Question michael5 Electrical 3 01-30-2007 11:38 PM
