New Circuit In Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 02:18 PM   #1
new circuit in sub panel
hello all i want to add a 20a circuit to an existing sub panel that runs my ac and heat. the circuit is for a 1.5 hp pool pump set up for 115v continous load.(plug type dont know what it draws) the sub panel is fed by a 45a breaker,the a/c draws from a 30a and draws 9.5 amps each leg the heat is connected to its own 15a breaker(wouldnt be on when pool pump is on) do i need to upgrade the 45a in the main panel? would it cause nuisance tripping on the 45a? Thanks
jenrator is offline   Reply With Quote
Old 05-29-2011, 02:46 PM   #2
Just call me Andrew
Rewards Points: 1,020
I don't think you'll have a problem. The only thing the pump would be competing with is the a/c. Even if the a/c used all 30A (it obviously doesn't), you still have a full 15A left....looks like (from google searches) 1.5 hp pool pumps use from 8-12 amps. I don't think you'll have a problem.
Andrew
secutanudu is offline   Reply With Quote
Old 05-29-2011, 07:02 PM   #3
tthat helpshanks Andrew
Old 05-29-2011, 07:21 PM   #4
Electrical Contractor
kbsparky's Avatar
That would be operating at 240 Volts. Double that number for 120 Volt operation.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
secutanudu (05-29-2011)
Old 05-29-2011, 08:34 PM   #5
Missouri Bound's Avatar
A 120V 1.5HP motor should draw about 1100 watts.....that's just around 9 amps. You should be good to go.
Old 05-30-2011, 06:45 AM   #6
kbsparky's Avatar
Have you checked table 430.248 in the Code? It shows a 1 HP motor requiring 20 Amps at 115 Volts.
Your calculations of using 746 watts per hp does not take power factor nor efficiency into consideration ....
-KB
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 09:04 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 12:52 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
