New Circuit Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 02:19 PM   #16
Sounds good, I have black and red electrical tape, I'm assuming I should use red on the white wires going to the 240v breakers.
I didn't torque them correctly though, just made them tight. I have a torque wrench at my parents house, if that goes low enough I'll loosen them, then torque properly, don't know that it goes down to 20-30 in lbs. Is it a huge deal to not use the exact torque?
banjo is offline   Reply With Quote
Old 05-19-2011, 12:41 PM   #17
zpm
yeah, right
If it wasn't important, they wouldn't tell you to do it.
The basic reason you torque something is to make sure it doesn't work loose due to expansion and contraction. Too little and there's not enough tension on the threads. Too much and you can damage the threads.
Those folks that come here with 180 volts on L1 and 60 volts on L2? Loose neutral which may have been prevented by properly torquing the feeders.
BTW, typical auto torque wrenches start at about 20 FOOT pounds, which is 240 INCH pounds.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 10:04 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 01:52 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
