New Circuit Breaker In Old Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 08:11 PM   #1
new circuit breaker in old box
I have an old mobile home with an old circuit breaker box. Can I put a new breaker in it (let's take for granted that appropriate wiring will be added also.)?
Littlebit03 is offline   Reply With Quote
Old 05-06-2011, 08:13 PM   #2
Electrical Contractor
kbsparky's Avatar
Is there a space available for another circuit?
-KB
Old 05-06-2011, 08:23 PM   #3
Licensed electrician
Rewards Points: 1,284
Can you get the correct breaker for your old panel?
Old 05-06-2011, 10:47 PM   #4
" Euro " electrician
frenchelectrican's Avatar
It depending on the model number of that breaker box some can have room and some don't so either post the model number or take a photo one of us will able indentify it.
Just be aware when you take the cover off from older breaker box some case the breakers may fall out of the place so the safest way is turn off the power at the meter socket location most mobile home will have extreal disconnect switch so use that before you open up the panel box.
Merci,
Marc
circuit breaker? blueandyellow Electrical 7 01-30-2011 11:27 PM
Need to ID old circuit breaker box oldfeller Electrical 11 07-26-2010 05:00 PM
A/C unit keeps throwing circuit breaker MofElPaso HVAC 15 05-03-2010 12:06 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
