Old 11-28-2008, 01:49 PM   #1
New Circuit
I am trying to install a new circuit for my attic. My main problem is that my garage--where my circuit panel is located--is finished. How, without tearing holes in the wall, can i run the wiring from the breaker panel to the attic? ( I know there will be some tearing of the wall, but what is the best way or way with minimal impact?) Thanks
chrisatola is offline   Reply With Quote
Old 11-28-2008, 02:07 PM   #2
Electrical Contractor
kbsparky's Avatar
New Circuit
Fish tape!
What is above the garage? Attic space? What type of siding is outside of the garage, behind the electrical panel? How about your soffit? Is is vinyl?
Old 11-28-2008, 02:13 PM   #3
kbsparky's Avatar
New Circuit
Here is another option if you don't like the idea of fishing wires down to your panel.
Cut in an access panel:
Old 11-28-2008, 02:14 PM   #4
New Circuit
The attic is above the garage. That is also where I want to add the new circuit. The panel is inside the garage. My home's exterior is brick, with some wooden siding. The interior of the garage--and what surrounds the breaker panel--is sheet rock. Thanks.
Old 11-28-2008, 02:35 PM   #5
joed's Avatar
New Circuit
You are going to need hole at the ceiling to drill through the top plate.
The only way around that is to use conduit and surface mount it to the wall, then up through the ceilng.
Old 11-28-2008, 04:43 PM   #6
J. V.'s Avatar
New Circuit
You will not have to tear any drywall down. Above in the attic drill a hole in the sill (top) plate right above the panel. Drill, so the hole is inside the wall. You might have to angle the drill some, but thats okay. Then you can fish a piece of NM down into the panel.
Old 11-28-2008, 08:34 PM   #7
New Circuit
You might not even need fish tape, drill the hole through the sill plate, push the wire down, grab it at the panel.
rgsgww is offline   Reply With Quote
Tags
attic installation, breaker, circuit, finished space, wiring
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
