Old 12-29-2012, 11:10 AM   #1
New ceiling light
I just put in a new ceiling light with 3 wires black white and ground that was wasy to install. When I hit the switch did not work. I replaced the switch also replaced the fan switch also. The fan switch had the 3 wire init then they just cut a piece of electrical wire to the light switch which had 2 different wires going into it which equals 2 black 2 white and 2 ground now the light won't turn off and the fan won't work. I put everything back the same way as i took it apart. I am a novice
dakota11 is offline   Reply With Quote
Old 12-29-2012, 11:17 AM   #2
A "Handy Husband"
rjniles's Avatar
New ceiling light
Obviously you did not. Post some pictures of both boxes.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-29-2012, 11:20 AM   #3
joed's Avatar
New ceiling light
If you tell us how you wired this new light then maybe we can tell you where you went wrong. The switch that did not work, did it not turn on the light or not turn off the light?
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-29-2012, 11:34 AM   #4
New ceiling light
i installed the lite black/black white /white and ground /ground the switch did not turn the light on or off as soon as i turned power back on the lite was lit but didn't shut off.... I did go over the wiring again i noticed that i only hooked up the ground from one switch to the other did not put the black or white back in.That is prob what went wongthese are the snap in type boxes where you put the wires in the box itself not the screws
Old 12-29-2012, 11:39 AM   #5
joed's Avatar
New ceiling light
What other wires were in the fixture box? Did you make any changes in the switch box? What wires are in the switch box?
Old 12-29-2012, 11:49 AM   #6
New ceiling light
The fan switch had a black white and ground going into it then it send all 3 out to the lite switch the lite switch also had to sets of wires going ito it 2 black 2 white and 2 ground..............I noticed I only sent the ground over to the lite switch from the fan switch not the black and white cause they had all 3 wires separtly not inthe casing
Adding Ceiling Light Raxas Electrical 3 05-13-2012 02:00 PM
Ceiling Light Help - Quiz - 3 sets of wires roundbox52 Electrical 1 03-28-2012 08:08 PM
Help- cant get a new ceiling fan light to work boddabing Electrical 6 08-26-2010 06:24 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 11:30 AM
