New Ceiling Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2007, 12:29 PM   #1
Smile
New Ceiling Fixture
Hello, Iwant to install a NEW cieling fan where there is NO existing fixture. My current setup is as follows:
Wall Switch controls 3 or 4 outlets.
What I want:
Wall Switch to control new ceiling fan, and to not control any of the outlets.
How should this be done?
Thanks,
Darren
Dhaz is offline   Reply With Quote
Old 12-10-2007, 03:31 PM   #2
joed's Avatar
Rewards Points: 12,370
Run a new 3 wire + ground cable from the new fan location to the switch. use 14/2 if 15 amp circuit and 12/3 if 20 amp circuit. Mount a fan rated junction box in the ceiling.
What happens next depends on how the switch and receptacles are currently wired.
Open the switch box and tell us all the wires and connections in there. If there is only a black and white and they are both connected to the switch then you will also need to tell us the wires in the receptacles as well. Are the receptacles switched on both sockets or is only one socket switched and the other stays on all the time? Is there only one switch that controls the receptacles?
Old 12-10-2007, 03:56 PM   #3
Electrician philosopher
Hey Dhaz,
Remember that when working on the switch, turn the power off except when testing for voltage. Don't check for voltage unless you are comfortable doing so. Also, before you dismantle anything, draw a diagram showing where every wire goes. That last step can save headaches later.
Andy
Andy in ATL is offline   Reply With Quote
want to make ceiling light fixture into plug-in lamp Cahill_Main Electrical 8 01-31-2008 03:55 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
Installing Ceiling Fixture schack44 Electrical 3 05-23-2007 07:51 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
