New Ceiling Fan - Elec Run A Little Short - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 05:02 PM   #1
Ron Paul 2012
New Ceiling fan - elec run a little short
Hey guys,
I am installing a new ceiling fan in my parents house and when I took out the old fixture, I found the wire to be short for mounting the ceiling fan. Meaning the junction box that comes with the mounting for the ceiling fan will only make it if you pull the electrical in the ceiling fan leaving a lot of tension.
Originally, I was going to mount another junction box in the ceiling where I would pig tail and run over to the ceiling fans box.
HandymanCA is offline   Reply With Quote
Old 09-16-2012, 05:38 PM   #2
Licensed electrician
Rewards Points: 1,778
Are you saying the wiring in the ceiling box is too short? Add additional length with a splice.
Old 09-16-2012, 06:52 PM   #3
Also make sure the box can support the weight of the fan. You shouldn't install a ceiling fan if the box is just a simple plastic nail on. You need a heavier duty box for that application.
Mattme123 is offline   Reply With Quote
Old 09-20-2012, 01:55 PM   #4
Ron Paul 2012
Update:
I installed a support between the two ceiling rafters in the attic that has a junction box already fastened to it. Feels like I could do a pull up on the bar and my ceiling fan is only 25lbs-45lbs.
Also, I picked up some additional Romex type nm-b 14/2 and one of the blue junction boxes to secure into the rafter. The plan now is to splice / pigtail (not sure on terminology) with wire nuts and secure junction box to rafter in attic.
Tonight, I will take pictures and update you guys on how everything is going .
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 04:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 09:27 PM
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 07:52 PM
elec wire is too short gary h Electrical 24 04-21-2010 09:13 PM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
