New Ceiling Bat Insulation With Old Attic Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2010, 10:16 PM   #1
new ceiling bat insulation with old attic wiring
I'm looking to install new r30 bats over exhisting(looks orgional) '61 (romex I think)wiring. Is this a fire hazzard? They are layed on ceiling joists without being in conduits. Is this normal?
1961fixer is offline   Reply With Quote
Old 04-13-2010, 10:29 PM   #2
What type of wire ?
NMB (romex), single wires, knob & tube wiring ?
Pics ?
Romex is fine to lay across joists
I usually will try to put boards up to walk on so that I do not step on the wires & do not go thru the ceiling
The Following User Says Thank You to Scuba_Dave For This Useful Post:
1961fixer (04-13-2010)
Old 04-13-2010, 10:33 PM   #3
Rewards Points: 506
If the wires are on ceiling joists, wouldn't the new bats go under the wires, rather than over? Do you actually plan to place the insulation over the wires?
If you think it is romex, then it could be normal to lay on joists without conduit. Assuming it is a NM cable.
jlmran is offline   Reply With Quote
Old 04-13-2010, 10:56 PM   #4
That begs the question, why can't i run batts over the 2x3 joist trusses lon g ways? it seems it would be a lot easier to cover over both wires and the plastic replumbed water pipes if its safe to? I'm in FL so freezing water isn't a problem.
Old 04-13-2010, 11:00 PM   #5
Rewards Points: 506
You've transitioned from ceiling joists to trusses. I think I may be confused about what you're attempting.
If you're talking about covering everything with the bats (joists, wires, pipes, etc.) then you might consider SubaDave's comment above. If you cover the joists, then you might not know where to walk in the future. Might end up with a shoe-full of sheetrock if ever you need to enter the attic.
Old 04-13-2010, 11:09 PM   #6
They are both prefab roof trusses in the low pitch attic and my ceiling joists. It's only 3 or 4' inside at the ridge.
Old 04-14-2010, 12:01 AM   #7
prefab roof trusses from 1961??
You might want to take a picture and post it, it would give readers a clearer picture of what you have.
voltech is offline   Reply With Quote
Old 04-14-2010, 01:11 AM   #8
You CAN go over the wires and plumbing with insulation, but ONLY if there is insulation underneath the wires already.
Insulation will NOT work if there is an air gap between the wall surface and the insulation.
What I did in my attic was I laid down 6" insulation inside of the joists underneath the wiring and plumbing. Then I went back with a second layer of insulation in the opposite direction on top of the joists and wiring.
After I did all that work, I realized that it would have been MUCH easier to just blow loose cellulose insulation into the attic.
Shrute is offline   Reply With Quote
Old 04-14-2010, 08:12 AM   #9
Rewards Points: 1,500
I would have thought that the air gap (without cracks between batts leading to the outside) would not make any difference and might even increase the insulating qualities provided that the insulation batts were fluffed to the same thickness (not squashed where they passed over the wires).
There should not be insulation between water pipes and the inside wall surface even if you do have to squash the insulation batts in the remaining space behind the pipes.
Now I never understood why knob and tube wiring could not be surrounded by insulation given the same gauge wiring and same electrical usage (load) as for Romex cables run through the same insulation.
Old 04-14-2010, 08:21 AM   #10
Insulation is installed in a ceiling before it is sheetrocked
Then strapping is run across the rafter joists & sheetrock is added
This creates an air gap & the insulation still works
But you are better off without an air gap, especially as large as 2.5"
Best to fill the lower area 1st, then add more on top
Several states have OK'd insulation w/knob & tube
There are requiremsnt - usually an electrician has to inspect & approve the K&T 1st
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 10:19 PM
Extending finished attic insulation stops? Mitch H HVAC 2 12-09-2009 11:00 AM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 05:19 PM
Idea for attic insulation baffles. What are your thoughts? Ininkus Building & Construction 8 02-26-2009 12:46 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
