New Cable In Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 04:01 PM   #1
Rewards Points: 52
new cable in attic
When adding a new cable through the attic, about a 12' run for a lighting circuit, I believe that I do not need to staple it to the joists as with new construction, so a) would like to confirm that, and b) is it preferred to lay the cable on top of the insulation, or run it under the insulation, directly on top of the drywall? And I may still roll back the top layer of rolled fiberglass, and staple it to the joist, but it's tight, so just thinking ahead to my options.
Old 01-30-2014, 04:08 PM   #2
Rewards Points: 13,274
It needs to be stapled, it should not be run over the insulation where someone could step on it.
Run it along side of the joist, though drilled holes in the joist, or stapled to 2, 2 X 4's nailed together in an L shape to protect the wire.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
DexterII (01-30-2014), plummen (01-30-2014)
Old 01-30-2014, 04:40 PM   #3
Rewards Points: 52
Thanks, Joe. Yeah, was thinking about it more after I hit the send button or whatever, and decided, nope, it's an attic, not a wall cavity, so no way around it. Aw well, only about 12' of it, so will get down on my belly and get to it, once it warms up a few more degrees.
Old 01-30-2014, 07:41 PM   #4
joed's Avatar
Rewards Points: 11,998
Only needs to be stapled to the top of the joist unless within six feet of the opening where it needs protection from damage.
Armored cable shell as conduit? sixspeed Electrical 13 10-18-2012 04:45 PM
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 12:50 PM
attic stairs for attic hvac installation scrolup HVAC 1 04-15-2012 01:53 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
