New A/C Service? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-30-2011, 05:19 PM   #1
New A/C service?
Do I have to use BX from the panel to disconnect? Or is 10/3 romex OK?
ziegler is offline   Reply With Quote
Old 07-30-2011, 06:03 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Depends on many things. Maybe yes, maybe no.
Considering the level of detail in the question the only accurate answer is maybe.
I don't know. Why do you assume #10? Why do you assume 3-wire?
Is it 120v?
240v?
120/240v?
Does the unit require a neutral?
What is the minimum circuit ampacity?
What is the maximum allowable circuit breaker?
Speedy Petey is online now   Reply With Quote
Old 07-30-2011, 06:49 PM   #3
What does BX/conduit/romex/THHN have to do with wire size? The old line was romex but the guy at home depot thought I was craze for using romex.
Old 07-30-2011, 07:06 PM   #4
That is what I was asking you. That is why I asked why you assume 10/3.
Well, you can listen to a home depot monkey, or you can come to a place like this and get real answers.
So, if you can answer some of my questions we can get started.
Your location would help also since many areas have local restrictions.
Old 07-30-2011, 07:49 PM   #5
I=E/R
a7ecorsair's Avatar
So, you have an existing A/C circuit that has a disconnect in place and it is fed from the main with romex, is this correct?
You need to tell us a little more about your project and why you were discussing this with HD. Are you having some type of problem you are trying to fix or are you upgrading?
There is nothing wrong with using romex but it cannot be run outside except to a disconnect box that is mounted on the exterior wall as long as romex is permitted in your area.
a7ecorsair is offline   Reply With Quote
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 07:55 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
