New A/C Old Wiring. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2008, 07:03 PM   #1
Question
New A/C Old wiring.
Hello everyone!!
Im wiring my New Furnace to my box.
Ran into a problem. I have 3 wires coming from my box, they are Red Green White.
The wire coming from my furnace are Red Green White Yellow Blue.
How do I condence these wires down to make the connection????
witly74 is offline   Reply With Quote
Old 10-13-2008, 07:07 PM   #2
You need to look at the wiring diagram.
I have no idea what the extra wire are for.
Control wiring?
1120/240 option?
220/221 is offline   Reply With Quote
Old 10-13-2008, 07:15 PM   #3
DIY'r
ScottR's Avatar
Just to be clear, by box do you mean electrical box, control box, or thermostat?
The wires you describe at the furnace sound like the colors for a 5-wire thermostat, is why I ask. Red, Green, White sounds like electrical though.
ScottR is offline   Reply With Quote
Old 10-13-2008, 09:16 PM   #4
Unhappy
The problem im having is with the thermostat wires. this set up im using has been working. ive cut the wires by mistake. im trying to re-establish the connection with the thermostat to the furnace, the electritian originally connected the 5 wires from the furnace unit (thermostat wires) to the 3 wires coming from my power box. somehow he condenced the 5 wires down to make the connection with the 3 wires coming from power box. My thermostat still has power. but the connection to the furnace unit is interrupted. in short im trying to figure out what color comination he used to connect th 5 wire thermostat wires to the 3 wires coming from my power box.The 5 wires coming from my furnace is Red Yellow Blue White and Green. The 3 wires coming from my power box is Red Green and White.
Old 10-14-2008, 08:14 AM   #5
An old Tradesmen
Rewards Points: 7,802
Heat only applications.
The 24 volt wiring is Red, and White, if the stat doesn't require a common.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 03:56 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
