New Bulbs, Good Fuse, Still No Lights...HELP! - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 09:08 PM   #1
Rewards Points: 77
New bulbs, good fuse, still no lights...HELP!
Hello, let me first say that this is my first post and I stumbled across it looking for answers to my problem.
My wife flipped one of two light switches on in our bathroom but she said everything popped and the lights were out. She said the pop was similar to when a bulb burns out. I changed the bulbs...no power...I flipped the other switch in the room and it works. I'm not sure how the house is wired but I'm assuming the bad switch is on the same as everything on both sides of that wall but I checked the fuse box anyway and nothing was blown. I took a switch out of one of the other rooms that I know works and replaced it but still no lights. We're trying to keeps costs down and are hoping this is an easy fix.
Any thoughts and ideas are much appreciated. Thank you!
TJMS81 is offline   Reply With Quote
Old 02-25-2009, 05:56 AM   #2
could be the switch. Turn off the power, remove the switch and either use a tester between the two points or jump the two wires together, turn the power back on and see if the lights work.
take no chances with electric. if youre not sure you can do it than call a pro
II Weeks is offline   Reply With Quote
Old 02-25-2009, 06:08 AM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Your bath lights may be run off of a GFI receptacle, although they shouldn't be. Check the GFI receptacles in every bathroom to see if it's tripped.
wirenut1110 is offline   Reply With Quote
Old 02-25-2009, 07:02 AM   #4
I know this is going a little far but, do you have aluminum wire?
Check for tripped gfis.
Otherwise, there may be a loose connection. These aren't fun to find without a multimeter.
rgsgww is offline   Reply With Quote
Old 02-25-2009, 08:51 AM   #5
jbfan's Avatar
Rewards Points: 478
If you do not find a gfci, remove the light fixture in question and check the wiring there.
jbfan is online now   Reply With Quote
Old 02-25-2009, 09:41 AM   #6
Rewards Points: 1,512
Did you replace or install something (other than a light bulb) before the first pop happened?
You might have made a wiring mistake.
Old 02-25-2009, 12:42 PM   #7
Rewards Points: 160
GFCI's make a switching sound when they trip. That could be what she heard. Reset the GFCI. While your at it, take a second to push the test button. Then reset it again to make sure it's working.
Old 02-25-2009, 02:16 PM   #8
known good bulbs?
nothing was blown.
Could be a wirenut gave up the ghost, with an arc
Almost certainly it is not the switch, unless a short somewhere causes switches to instantly fail.
I assume your wife passed the Polygraph exam?
Old 02-25-2009, 03:01 PM   #9
the Musigician
DangerMouse's Avatar
i'd cut the power and pull the light. you might just find a fried socket or dead wires. (burned/hard/falling off/touching each other not in a fun way/socket crumbling) i just fixed one like that 2 days ago.
the guy had 2 100w bulbs in the fixture... rated at 60w max x2.... stamped right on the steel.... can't miss it.......gee, wonder why that happened? heh heh
DM
Old 02-26-2009, 06:25 AM   #10
Rewards Points: 77
Thank you everyonefor the posts. I used my multimeter to make sure the switch was still working yesterday...it was. There is a single outlet wired with and part of the light assembly so I used that which told me power was getting past the switch. The bulbs had been 100W but the assembly was rated for 60W (I was replacing w/ 60W). It still wasn't working so I loosened the mounting nut and was going to take a look at the wires. As an after thought, I put in a 60W and it came on. I looked for bad wires but couldn't see anything loose or bare anywhere. I replaced the mounting nut and put in 4 good bulbs. I'm not sure what was going on but it is all working now, thankfully.
Old 02-26-2009, 09:52 AM   #11
This is just a quick note, I have found that the center tab in the middle of the light socket will sometimes be bent so far in the socket you will get intermittant connection. Make sure the tab is clean & bent outward.... Then again you can usually get a replacement socket from the hardware store for a couple bucks.
g.gauvreau is offline   Reply With Quote
Tags
bulbs , fuse , no power , switch
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 09:01 PM
Down lights placement issues? Ads79 Electrical 2 02-09-2009 07:54 PM
Goodman GMT-070-4 Furnace blows 3A Fuse Bruce Mundy HVAC 4 01-02-2008 10:31 PM
Halogen flood lights chicagonyc Electrical 5 07-15-2006 10:11 PM
fuse went BANG davej Electrical 1 01-23-2006 12:37 PM
