New Breakers In Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2009, 01:07 PM   #1
new breakers in conduit
i have some conduit ran in the garage with a j box already mounted previous owner had this done..the conduit is ran to my breaker box... i wanna add some new breakers to feed some plugs..romex cannot be used in conduit correct? should i just use MC to run in the conduit and when i get to the attic put a j box there and run with romex for the rest of the circuit? 15amps
thanks in advanced
Pledgeman is offline   Reply With Quote
Old 11-02-2009, 03:29 PM   #2
Child Alert! Pull Up!
fltdek's Avatar
What type of walls do you have? Block or wood frame? And is this commercial or residential, I am guessing residential, reason I am asking, why the need for conduit? If your dealing with wood frame, drill the holes and run the wire, to me would be a whole lot easier....
Which way does the conduit run from the panel? Does it run along the walls, go straight up the wall? Am I correct in thinking you want to install receptacles in your attic? The less junctions you have the better off you are - meaning less things to go wrong, so if you can run from the panel direct to your first outlet, thats what I would do.
fltdek is offline   Reply With Quote
Old 11-02-2009, 04:42 PM   #3
its woodframe but where the breaker box is .its a pain to drill a hole it on the edge near the eve..almost no space to get back there..a box is already in place with metal coating from one j box to panel..which is located above the box 8 inches or so..
second it runs down the wall..then across and ten back up....
Old 11-02-2009, 05:54 PM   #4
You can run romex in conduit as long as it is big enough
Local codes can vary
Old 11-02-2009, 10:11 PM   #5
fltdek's Avatar
As Scuba_Dave mentioned, you can run regular electrical wiring (Romex) in conduit as long as the diameter of the conduit will easily accomodate the wire. You may need a fish tape to pull the wire up thru, and if drilling a hole near the eve or top plate, then sounds like junctioning it there may be your simple soulution. MC cable would be like overkill, where as the conduit is a protective channel, MC cable is just the same, only flexible.
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 08:48 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
