New Bathroom Vent Trips GFI When Switch Is Turned Off. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 09:46 PM   #1
new bathroom vent trips GFI when switch is turned off.
Recently replaced a cheap, loud bathroom vent with a nice quite (.8 sone) model. Like the replaced one it is on the downward leg of a wall GFI. Never had a problem with the GFI tripping until I replaced the vent. Now, about every third or fourth time the switch to the vent is turned OFF, the GFI trips. Wiring is fine, it's a new 20 amp circuit I put in a year ago. Terminations are well insulated. Could it be something with the new motor? It's just a vent, no light but the bathroom wall lights are also on the same GFI.
Mike in Arkansas is offline   Reply With Quote
Old 11-16-2011, 09:43 AM   #2
No one know why a switch being turned off would cause a GFI to trip?
Old 11-16-2011, 10:18 AM   #3
If I were to venture a guess, it would be that the motor is generating enough current to trip the GFCI through inductance after power is removed. The reason it doesn't happen every time is that it's not generating much current and sometimes it's enough to activate the interrupt and sometimes it is not.
Roxerroneous is offline   Reply With Quote
The Following User Says Thank You to Roxerroneous For This Useful Post:
Mike in Arkansas (11-16-2011)
Old 11-16-2011, 10:43 AM   #4
There is a reason we don't put bathroom fans or lights on gfci protected circuits. If it is possible to refeed the fan I would.
Colomboj is offline   Reply With Quote
The Following User Says Thank You to Colomboj For This Useful Post:
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Bathroom venting near gable vent? jdhoskins Kitchen & Bath Remodeling 5 08-10-2011 10:54 PM
Switching on/off switch in one bathroom, ruined the other. Im stummped. Drea Electrical 2 02-08-2011 07:49 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
