New Bathroom Light Flashes & Blacks Out. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 08:59 PM   #1
new bathroom light flashes & blacks out.
I've changed out a few light fixtures before so thought this would be a simple project. Ha! I'd love input as to what I did wrong.
Took out the ugly old fixtures and got the black wire, white wire and copper ground wire. They are all doubled but I don't think that matters. The mounting bracket was wrong so I put up the new one with mollies, and I'm pretty sure I didn't drill into anything in the wall but could never be 100%
I got all the new wires hooked up, got a big flash, blew out the bulb, then nothing. Hung the alternate fixture, got another flash, then it went out. bulb didn't blow this time.
re mounted the original fixture, and get the same thing. flash and it goes out. It's been hanging there laughing at me for a week. I keep forgetting and hitting the lightswitch, and get a flash and again out. If I then try to turn it back on, it just stays out. It doesn't pop the GFI or the breaker, and the other lights on the same switchplate stay on.
I also replaced the switchplate but can't imagine that would do anything.
any suggestions?
rachelb is offline   Reply With Quote
Old 11-23-2011, 09:01 PM   #2
Electrical Contractor
kbsparky's Avatar
You may have pinched a wire when you mounted the new fixture, or driven a screw into a wire ...
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
rachelb (11-23-2011)
Old 11-23-2011, 09:05 PM   #3
Rewards Points: 150
Call an electrician. It could be an arc fault issue.
OhioHomeDoctor is offline   Reply With Quote
Old 11-23-2011, 09:23 PM   #4
Thanks. I have, but he hasn't made it here yet. I was hoping to beat him to it. Maybe I'll at least try undoing the bracket and see if I crimped the wire.
Old 11-23-2011, 09:24 PM   #5
Rewards Points: 150
Its best to leave that to a professional. Should just cost you the service charge.
Old 11-23-2011, 09:25 PM   #6
what's an arc fault?
Old 11-23-2011, 09:26 PM   #7
Rewards Points: 150
Its when zuess farts.....
Old 11-23-2011, 10:44 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,608
A flash means there was an arc,
That means you have either a wire with damaged insulation,
or a broken wire which is arcing over,
Carefully examine all wires for obvious damage
no matter how small, any burns or anything sus.
Last resort watch from a distance and have someone turn on the power,
you might see exacity where it is arcing over !
Be carefull, not too close !
dmxtothemax is online now   Reply With Quote
Old 11-24-2011, 05:01 AM   #9
__________________________________________________ __________
Well, maybe it does matter. You say they are all doubled. So are you including the switch wire with these?
You say light fixtures - plural . Are there two different fixtures? How many sets of wires come out at each fixture.
If you are taking the switch wires and hooking them black to black and white to white like everything else, it will blow the fuse every time !!!
Jim
jammin06 is offline   Reply With Quote
Old 11-24-2011, 06:37 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
I'm curious too, what is an arc fault?
Old 11-24-2011, 06:46 AM   #11
Rewards Points: 1,548
Where precisely did the big flash happen? In the light bulb or somewhere else (nearby?)?
Arc fault -- When two wires or metal parts almost touch where they should not touch and current flows across, jumping through the narrow air gap, producing a visible continuous spark.
An arc fault interrupter is a circuit breaker with electronics that sense that an arc is happening somewhere in the circuit and cutting the power when that happens. Because an arc generates heat and can start a fire.
Old 11-24-2011, 08:53 AM   #12
Allan, I know what an arc fault is, I was just asking the "Doctor".
Old 11-24-2011, 12:31 PM   #13
Not you. Her.:
Its when Zeus farts.....
Ah yes. He's the one who hurls the lightning bolts.
Old 11-24-2011, 01:34 PM   #14
lol Sorry Allan.
Old 11-28-2011, 08:25 PM   #15
Thanks everyone for the input.
scott the electrician came today.
the flashing from the fixture was the bulb turning on then immediately off. turns out the switch was faulty.
replaced that, and all is well.
this is a great site. I'll be back the next time I almost blow something up.
Thanks!
Bathroom vanity light - mount to single switch box? bsims Electrical 5 08-31-2011 08:57 AM
Replacing Bathroom Light with Fan quinten Electrical 5 10-29-2010 08:25 PM
Electrical bathroom vanity light fixture HEMMY1244 Electrical 4 09-29-2010 07:40 PM
Bathroom Light clarkey Electrical 2 09-04-2008 09:48 PM
Bathroom light with outlet in it? Jaded Electrical 12 04-15-2008 12:08 AM
