New Basement Circuit - Lights & Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 01:51 PM   #1
New Basement Circuit - Lights & outlets
I'm finishing my basement, and I've reach the part where I have to design the electrical wiring.
This is the current situation on our basement:
1 circuit on a 15-amp breaker that includes at 3 lights, plus 6 outlets.
We would like to add another circuit of around 12 lights, plus 2 outlets for a TV & Home Theather.
I've done some research, and I'm not sure if it would be best to add 1 breaker of 20 amps for the new circuit, if that would be enough, or if I should split some of the new circuit outlets and/or lights with the existing circuit.
What do you guys recommend me to do?
Jallolo is offline   Reply With Quote
Old 08-21-2013, 02:00 PM   #2
Licensed electrician
Rewards Points: 1,876
What is the maximum wattage the light fixtures will accept? The circuit load will decide the best course of action.
Old 08-21-2013, 02:14 PM   #3
It would be recessed light fixtures, and we won't go for more than 50 watts per bulb. It may be less, as I didn't buy the fixtures yet, but I know we won't go for more than 50 w.
Old 08-21-2013, 02:59 PM   #4
It does not matter the size bulb you install. The circuit is based on the largest bulb the fixture will accept.
Old 08-21-2013, 03:37 PM   #5
Rewards Points: 676
Are you going to be doing this under permit or on the side? Any new circuits added to livable space need to have an AFCI breaker in the box at about $40 per pop.
B
Beepster is offline   Reply With Quote
Old 08-21-2013, 11:53 PM   #6
" Euro " electrician
frenchelectrican's Avatar
And the location where ya due some case there are some change on the NEC code or Canada codes depending on where ya at.
Merci,
Marc
Old 08-22-2013, 06:50 AM   #7
The one I've been looking at are 50 watts max. We can assume I'll buy one of those.
Old 08-22-2013, 06:51 AM   #8
B
I'm in Montréal, Canada. Not sure what the regulation in my area is. I'll have to check about that.
Thanks.
Old 08-22-2013, 08:15 AM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Thanks.
That's easy then.
Canada can not have lighting on a 20 amp circuit.
Old 08-22-2013, 11:32 AM   #10
Originally Posted by jbfan View Post
That's easy then.
OK, then. I guess that solves the 15-amp vs 20-amp issue.
Now the question is, would a 15-amp breaker do the job for 13 50 watts max. light fixtures, plus TV & Home Theather, and maybe gaming console???
Should I be better by putting all light fixtures in the new circuit (3 existing 100 w max, plus the 13 50 w. max), and keep all outlets (6 existing plus 2 new) in the current circuit?
Old 08-22-2013, 12:46 PM   #11
Philly Master's Avatar
Rewards Points: 516
that's easy then.
what ?????????
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 08-22-2013, 06:17 PM   #12
jbfan's Avatar
Rewards Points: 650
Originally Posted by Philly Master View Post
what ?????????
Wait until some of our Canadian sparkys come along.
Old 08-22-2013, 07:20 PM   #13
dmxtothemax's Avatar
Rewards Points: 5,604
The best option would be to have two circuits,
One for lights only,
The other for outlets only.
That way if you overload a circuit.
you don't plunge the entire basement into darkness,
by taking out all the lights as well !
dmxtothemax is offline   Reply With Quote
Old 08-22-2013, 11:47 PM   #14
what ?????????
I will vocher the Canada regulations and all the lights ( luminaries ) have to be on 15 amp circuit ( some area will required AFCI now )
I know Joed and couple other they will post the correct Canada code number to back this up so hang on a bit.
For my French codes it simair and only differnce that all the hardwired luminaires are required to be on 10 amp circuit ( of course RCD'ed protected )
Merci,
Marc
Old 08-23-2013, 07:30 AM   #15
That is very doable, as I can easily remove the existing lights fixtures from the current circuit and move them to the new circuit, for lights only.
However, I'm worried that the current circuit - 15-amp, 6 outlets - would do the job if I add 2 more outlets. Would that support all possible appliances in the basement? Bare in mind that it would be a family room, and it is very possible that at the same time a TV, a home theather, a gaming console, a computer and treadmill will be running.
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
Maximum lights on a single circuit sbazzle Electrical 3 02-15-2011 08:43 AM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
Can I use lights and outlets on same circuit? heyd Electrical 4 08-24-2010 12:05 PM
How many lights on a circuit? How many outlets? helpless handyman Electrical 4 04-14-2008 12:11 PM
