New Attic Fan Didn't Last A Day - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2009, 04:20 PM   #16
Originally Posted by JRMN View Post
@J.V., well my brother wasn't able to help, but he did allow me to use his tools. Everything was working fine last night; however, I plan to check to make sure everything is still working when I get home from work.
@Wildie, when you say supply ventilation, you mean other vents in the attic to allow air to flow in right? If that's the case then I believe I have 3 other shutters/vents.
Yes! You must have vents such as soffit vents etc!
Old 08-27-2009, 11:53 AM   #17
Rewards Points: 204
What do you mean by that? Restricting air flow lowers current. Blocking the suction or discharge side of any fan will cause the current to plummet.
Is there something about attics that would make this fact untrue?......Thanks
Old 08-27-2009, 07:15 PM   #18
I'm not a physicist, but if you have a sealed room with a fan drawing air out it will lessen the atmospheric pressure in the room.
Outside atmospheric pressure wants to flow back into the room and equalize the pressure!
If the fan is running in a certain direction, and then power is abruptly stopped, the fan will stop and then start to rotate in the opposite direction, as air flows back into the sealed room as the pressures equalize.
This demonstrates the forces acting on the fan load.
Even though the fan may be running and blowing outwards, the outside atmospere is attempting to equalize the inside pressure, countering the outflow.
The result being a greater load on the fan motor.
If the room has an incoming air vent then the fan load is relieved as the incoming equalization will enter here rather than working against the fan.
Old 08-28-2009, 07:45 AM   #19
Rewards Points: 101
Hey guys, I have a guy coming out tomorrow morning. He's replaced motors, fan blades and entire units. Lets hope all goes well.
JRMN is offline   Reply With Quote
Old 08-28-2009, 11:41 AM   #20
Rewards Points: 204
No air to move, means less work and that means less current. This is a fact, not a theory. Same with a pump. Restrict the flow, you lower the current. Thats just how it is.
Now your comments regarding back flow? I see your point. It is highly possible if the fan is turning in the wrong direction and then it cycles on, that would cause an increased current for as long as it took to get the fan running in the right direction and the right RPM. You would think the manufacturer would have provisions to prevent this? Good question!
Maybe someone will chime in that knows more about this? Maybe an HVAC tech?
Old 08-28-2009, 12:01 PM   #21
I can see your point if the fan is in perfect vacuum, but its not. There are complex elements at work for an attic fan.
Anyway, back to the original problem! He wants to move hot air from his attic and I suggested that he should have incoming venting.
Much the same way in which a forced air heating system works, with its cold air return. Same idea!
Old 05-29-2012, 05:38 PM   #22
paul
What was the resolution to your problem?
pgeeman is offline   Reply With Quote
Old 05-29-2012, 06:07 PM   #23
Licensed electrician
Rewards Points: 1,762
Not sure the OP is still going to be here following this thread after almost 3 years.
Old 05-29-2012, 06:49 PM   #24
kevinp22's Avatar
Rewards Points: 252
Pgeeman,
seriously, im sure you didnt sign up just to follow-up on this old issue, but i wonder if you are having similar trouble and need help. if so, please post details, pics or both
kevinp22 is offline   Reply With Quote
Old 05-29-2012, 08:31 PM   #25
followup
I was reseaching a problem I am currently having when I came across your similar problem. I replaced 2 motors in the past 2 days and have no idea what to do. I checked voltage, thermostat and they are OK but never replaced the fan blade. The fan worked when I replaced the motor but when I went back to check on it later - it wasn't workinging. I was curious how you solved the problem.
Would be very much interested in an answer before I get an expert to look into it.
Old 05-29-2012, 09:11 PM   #26
kevinp22's Avatar
Rewards Points: 252
I have had my share of fun with wiring attic fans.
1, is there a disconnect switch somewhere? or a switch in the hallway you arent sure what it does. someone might have flipped it
2. are you sure a breaker hasnt tripped
3. there is usually a little toggle switch on the fan box to turn on the fan even if its below the thermostat temperature
4. most newer fans shut off if the temp exceeds 135 degrees in the attic to prevent the fan from possible increasing oxygen flow to an attic fire
5. you might have a loose connection between the box and the actual fan (there is usually a 2 foot section of armored cable between the 2 to protect the conductors. that is 4 places a connection with the hot and neutral can be loose
6. you could have a mechanical issue that is causing the motor to work too hard and burn out
Old 05-30-2012, 07:34 AM   #27
Rewards Points: 101
@pgeeman, in the end, I ended up having someone replace the entire attic fan. My brother recommended a guy he use to work with. Last year my house got hit pretty hard by hurricane Irene and I ended up having my roof replaced. I currently don’t have an attic fan because the roofer convinced me I didn’t need it. Supposedly it’s not needed because the new roof is vented. I figure, if need be, I could just install a gable fan. I have three gable vents on my house. I recommend you have a professional or a handyman replace the entire fan.
Old 05-30-2012, 07:36 AM   #28
kevinp22's Avatar
Rewards Points: 252
wow, i guess we have our answer!
Old 05-30-2012, 08:26 AM   #29
fan replacement
Thanks for your quick answer. I appreciate your help and decided last night to have the entire unit replaced (you backed up my decision) - I'll go to Home Depot and have them install it and then have a warranty against any problems if they should occur again.
Old 05-30-2012, 08:36 AM   #30
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I haven't seen anything installed by Home Depot that has lasted or that was installed correctly. Call a roofing contractor.
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
