New Addition - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 02:16 PM   #1
kbc1's Avatar
new addition
i am building an addition wat things should i make sure of for the electrical inspection, wat r things they look for
kbc1 is offline   Reply With Quote
Old 10-31-2012, 04:14 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 816
Proper spelling for one.
Your most likely going to be under NEC2011....
All your outlets need to be tamper resistant.
Neutrals in all your switch boxes.
Wired smoke detectors
If your adding bedrooms, AFIC's
Proper size wire
Enough outlets in your load center.
Old 10-31-2012, 06:41 PM   #3
Davejss's Avatar
Rewards Points: 740
[QUOTE=ddawg16;1041839]Proper spelling for one.
Your most likely going to be under...
"you're"
Proper spelling...
Davejss is offline   Reply With Quote
"Curb" under Pier Addition Thunder Chicken Concrete, Stone & Masonry 2 08-06-2012 04:31 PM
Addition between garage and home themuchky Building & Construction 10 01-26-2012 07:20 PM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 05:12 AM
Footing/Foundation for Addition stubits Building & Construction 1 03-11-2009 02:43 PM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 06:06 PM
