New 3-Way Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 08:16 PM   #1
New 3-Way not working
I updated some switches in my house. The old switches were probably 20 years old. They worked fine but just looked bad. Anyway, I bought new 3-way switches from Lowe's and hooked them up exactly as the old ones were. After doing one 3 way the kitchen light still worked but when i added the second the way for the same light, the light stopped working. I hooked the old switch back up and it works. Obviously, I dont wire the new 3 way the same way as the old. Anyone have any ideas? This happened in a kitchen and also in a hallway. The wires came out of the the switch as follows: Black to top left, red to top right and white to bottom right. A second switch in another part of the house for a different light was wired like this: Black to top left, black to top right, and white to bottom right. Again, when I wired brand new switches just like the old ones, neither light worked.
Hope this makes sense. I appreciate any/all ideas you may have.
cincycuse is offline   Reply With Quote
Old 02-04-2009, 08:27 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You can't go by the location of the screws. Look on the old switch and there will be 1 screw that's either marked "common" or a different color than the other 2 screws. This wire needs to be put on the black screw or "common" screw of your new switch. It doesn't matter which screws you put the other 2 on.
Other than the ground screw of course...lol
wirenut1110 is offline   Reply With Quote
Old 02-05-2009, 02:22 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
There is another Tread going with the same Subject
Light switch help
Disclaimer
& Stay Safe
.....Bob Lavery
No heat but working AC xevier69 HVAC 4 01-30-2009 05:31 PM
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 05:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
