New 240 Oulet...need Troubleshooting Help - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 07:05 AM   #16
Rewards Points: 1,548
Measure voltage in the subpanel between two fins under where the breakers snap on. Find two fins with 240 volts between them for your double breaker.
Old 08-16-2010, 10:19 AM   #17
Originally Posted by jbfan View Post
Check the placement of the breaker.
Ge panels are made so the whole panel with accept the thin breakers, and sometime you can put a thin 2 pole breaker into a single pole slot.
will do so after work..thanks...by the way...noticed that the electrician put a slimline ge 40 amp from the main to the subpanel....is this ok....can i get a 240 v feed from this type of breaker?
alfaman is offline   Reply With Quote
Old 08-16-2010, 10:24 AM   #18
Licensed electrician
Rewards Points: 1,876
That slimline breaker may only be supplying 120 volts to the subpanel.
alfaman (08-16-2010)
Old 08-16-2010, 10:49 AM   #19
ahh....how can i check this....i guess i could check the bus on the subpanel?.....
i will put a full size 40 amp double pole on the main to supply the subpanel
i'm still a bit unclear on how i place the full size in the panel to supply 240v instead of 120
Old 08-16-2010, 10:54 AM   #20
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
A slimline GE breaker double pole breaker will fir into a single slot, thus only delivering 120 volts on each side of the breaker, but not 240.
The breaker needs to be moved up or down 1/2 slot to get to both legs to supply 240 volts.
The Following User Says Thank You to jbfan For This Useful Post:
Old 08-16-2010, 01:26 PM   #21
Electrician
Proby's Avatar
First you have to tell us what type of cable is supplying the sub panel, size and amount of conductors inside.
Pictures of the sub panel and the breaker feeding the sub panel inside of the main panel would be best.
For all we know right now, that sub panel might be wired up with a piece of 12-2.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-16-2010, 03:38 PM   #22
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yep that is my bet too 120 volts only feeding his sub-panel
A THQP slim line double has enough gap between the two breakers so that it can be installed on a single bus stab. There are two tabs that project 90 degrees from that stab both are the same bus so the breaker is 120 volts. You have to do as JBfan said to catch a single tab from different bus stabs. The full size THQP does not use these tabs but the bus stab itself. See image below.....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
Old 08-16-2010, 06:24 PM   #23
Thanks guys..will check this out after work when i get home....
apprecitate it!
Old 08-16-2010, 08:54 PM   #24
thanks guys..fixed...it was that slimline breaker in the main...i'll be welding this wkend!
Old 08-17-2010, 09:00 AM   #25
jbfan's Avatar
Rewards Points: 650
Great! Have fun.
newbie HVAC troubleshooting elm66 HVAC 1 06-22-2009 08:38 PM
Tips On A/C Blower Troubleshooting? DeeTee HVAC 7 05-21-2009 12:24 PM
1986 Day&Night Troubleshooting...HELP!! rwhite692 HVAC 3 05-06-2009 11:32 PM
Troubleshooting Garage Light capt2 Electrical 10 11-18-2007 10:41 AM
Help with voltage troubleshooting epicurux Electrical 5 07-02-2007 07:51 AM
