New 200 Amp Panel Had Salt Water - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 02:22 PM   #1
Smile
new 200 amp panel had salt water
A one year old 200 amp panel with 25 circuit breakers was compromised in my basement from Hurricane Sandy any idea's what to do besides dumping it.Thanks Joe
fdny343 is offline   Reply With Quote
Old 11-07-2012, 02:31 PM   #2
Rewards Points: 13,300
That's about all you can do.
Also all the wires will need to be cut back and restriped because there going to corrode.
Old 11-07-2012, 04:17 PM   #3
Licensed electrician
Rewards Points: 1,296
Replacement of flooded equipment is the only choice.
Old 11-07-2012, 04:48 PM   #4
...have a electrician or two give her a look....you may...may be able to replace the guts...the buss and breakers....this will save some labor maybe..but very marginal amount....best off rippen her out and putting in new...I would suspect your homeowners should cover...hopefully....
Bobka is offline   Reply With Quote
Old 11-08-2012, 12:33 AM   #5
" Euro " electrician
frenchelectrican's Avatar
I am pretty much the same page as other mention dump that panel which it allready damaged with water it don't matter if fresh water or salt water both can do hovac damage.
Ditto with the breakers., Once they dunked in the water it pretty much done for it.
The conductors it kinda iffy depending on which way but genrally best to replace it as well you may have to go above the water line where it was flooded once above that it should be pretty good but keep in your mind the cable and conductors can wick it up a bit.
Merci,
Marc
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 09:57 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
