#1 |
New 200 Amp Breaker box make noise
I installed a new GE 200A electrical panel and transferred all of my circuits over from the old box. All of them were working fine in the old box. I just needed a bigger box. Anyway, after energizing the main breaker it made a sizzle sound for a second or so and then quit. Kinda freaked me out. I turned it off. I checked to make sure it was seated fully and it appeared to be. I then turned off all circuits and then turned on the main. No noise. I started turning on circuits one at a time. After the fifth or sixth breaker I heard that sound again only it was very faint. so I assumed something was wrong with that particular circuit. I rechecked the connections and tried it again. No noise. So I turned the rest of the circuits on and all was quiet.
I then turned off the main and cleaned up the work area and put the panel cover on. After energizing the main break I heard that noise again. I quickly turned it off and after checking the panel here is what I've discovered:
Do you think this is a bad main breaker? The service lines are newly installed by the power company and are locked. Could they possible be loose or not tightened to spec? What would cause this? |
#2 |
JOATMON
Assuming your incoming power is tight at the lugs....sounds like you may have a bad main breaker....it happens....
If new, I would replace it.....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
You can also check the bolts that attach the main breaker to the bus.
Electricity will kill you if you give it a chance |
#4 |
I checked the tightness of the lugs and the breaker and they were fine. So I replaced the main breaker with a new one and it works perfectly. Afterwards, I was inspecting the breaker that I removed and noticed a stink bug in the space between the break and the copper bracket that bolts to the bus. So I'm wondering if that sizzle could have been the stink bug being fried?
| Display Modes | |
| Added new breaker, no garage lights now. | lum1nes | Electrical | 8 | 08-04-2012 08:50 PM |
| breaker keeps tripping | RMCarner | Electrical | 29 | 07-22-2012 10:53 AM |
| Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker | sunrise | Electrical | 1 | 05-13-2012 08:27 PM |
| Outside breaker, inside main breaker panel, so is it a sub? | CPF | Electrical | 29 | 02-01-2012 11:28 AM |
| Is it possible to change Circuit breaker to Buss fuse socket type? | njchen24 | Electrical | 8 | 08-07-2011 07:27 PM |
